      05-02-2013, 11:22 AM   #1
bmw_merica
Drives: 2013 BMW X5d
Will fender flares fix this look? *Updated with Additional Pics*
Ok guys, long story short, I am stuck with a set of wheels that I can't return, so that's not the option. I know it's not the most ideal offset but it's extremely aggressive.
Will fender flares help line up the tires with the fender to give it a more complete look? Before you say it looks ricy, I can't do anything about it so keep your negative comments to yourself. I may have to go a custom route for flares I guess if OEM flares won't work.
Thoughts? Reason I ask is cause I know the rear fenders protrude about 2" but I doubt the fronts extend that much from other people's pics.
Uploaded with ImageShack.us
Last edited by bmw_merica; 05-05-2013 at 09:17 PM.. Reason: Added more pics as requested
      05-02-2013, 11:59 AM   #2
mrmomo313
mrmomo313's Avatar
Drives: M6 Gran Coupe
yup. how wide are those tires? even the 295s that I have up front don't come up to the flares.
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension
2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown
DME Stage 3
      05-02-2013, 12:19 PM   #3
bmw_merica
So fender flares will make this look ok up front? The fender flares aren't that wide in the front right? Maybe .5"?
They are 295s but 10.5" wheel...don't ask haha
      05-02-2013, 02:13 PM   #4
reading1800
Drives: E70 4.8 2009
2009 E70  [0.00]
I have them to sort the 215s , look fine and definitely needed.
      05-03-2013, 09:57 AM   #5
P1
P1's Avatar
11569
Drives: 2004 3/4 ton Duramax
Want to show us a few more pictures? Hard to tell with just one. Also interested in seeing what the wheels look like.
      05-03-2013, 10:42 AM   #6
grn.eyed.bandit
can you stand it?
grn.eyed.bandit's Avatar
Drives: 2010 Touring
You may also be able to have the hub of the wheel professionally machined in order to have it sit more in the wheel well.
__________
When I get sad, I stop being sad and be awesome
__________
      05-03-2013, 11:02 AM   #7
blue dragon
Drives: '22 Tesla MY + '23 Tesla MY
Flares will make that stick out just the right amount to be aggressive
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      05-03-2013, 01:49 PM   #8
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Add flares and you'll be all good.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      05-04-2013, 09:05 PM   #9
wsybert
wsybert's Avatar
Drives: 2009 BMW M3 Vert
Flares will make that look nice and aggressive. Go for it.
      05-05-2013, 01:14 AM   #10
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5M & X5 35d
With flares that should be money I would like to see a few more pictures of the wheels.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      05-05-2013, 09:01 AM   #11
turbologist
Emperor
turbologist's Avatar
Drives: tricycle
Werd...
      05-05-2013, 06:58 PM   #12
rh71
rh71's Avatar
Drives: '08 X5 3.0si
front flares definitely don't stick out as much as the rears but seeing as you're stuck with these wheels that's about the easiest solution at this point. Think it'll still look great.
'08 X5 3.0si - Alpine White -> more pics <-
      05-05-2013, 09:24 PM   #13
bmw_merica
Pics as requested! It's hard to tell with the angle but they are a deep concave design. I will get more pics up when I get everything washed up and cleaned.
Finally got them mounted (pic above in original post is test fit). The rears definitely need spacers. I have the fender flares on order -- once these are put on I am going to measure what size spacers I will need for the rears to sit flush, but they are pretty tucked under for being 10.5" wheels with et +38 offset. Any recommendations on spacer size or at least ball park?
      05-06-2013, 11:15 PM   #14
Sylvan Lake V35
Vanilla Gorrilla
25mm spacer in the rear with a 10.5 +38. Your tires look a little skinny(might just be the picture) so maybe even a 30mm spacer if the rears are <315mm
