      01-16-2020, 07:07 PM   #1
greekster
Drives: 2010 X5M
F85 drivetrain + harness + ecu
Hello all,
Hypothetically speaking, if i get an f85 donor car, would it be possible to swap the entire drivetrain (engine + trans), cluster, wiring harness and ecu into the E70 and make it work? Or would it be easier to use a stand alone ecu ie: motec?
      12-14-2021, 10:38 PM   #2
TTV8M
TTV8M's Avatar
124
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
eh, might b a super-duper frankenstein, as the independent modules talk to each other, and w the E to the F chassis, a lot has changed.
'10 X6M
'08 Cooper S
      01-09-2022, 12:42 PM   #3
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Originally Posted by greekster View Post
Hello all,
There's a guy who LS swapped his x5m and its got the ZF8HP transmission connected to it (e70 x5m had zf6HP). So in theory.......you probably could (with the obvious work, headache, and custom fitment).
