      12-02-2015, 09:42 PM   #1
Mnite_S63
Drives: 2013 F13 M6, 2010 X5M
X5M Eurocharged Owners
Hello all,
Finally got a chance to flash my X with the Eurocharged tune. Just wanted to compare if the experience I had was the same.
Once I started the flash
-Car made rear noise errors lit up 4x4 height etc.
-After flash Check Engine light came up and had to start up 5x to clear up.
Any input would be great.
Thanks
      12-02-2015, 10:24 PM   #2
Dr.Duct_Mossburg
Dr.Duct_Mossburg's Avatar
59
Drives: Space Gray · E70 X5M
Can't comment specifically on Eurocharged but i just did the Velos flash tonight and it did the same thing. All kinds of error, check engine lights. When it started most cleared out. I started the truck 3 or 4 times and the CEL went away and everything was back to normal... well except for the extra HP's.
      12-03-2015, 10:48 AM   #3
Omar@VelosDesignwerks
Omar@VelosDesignwerks's Avatar
Drives: Different Ones
Originally Posted by pcotangco View Post
Hello all,
Thanks
Yes you can either clear the codes or start the engine and turn it off 4-5 times.
      12-03-2015, 02:39 PM   #4
Creamo3
Drives: 2012 Alpine White X5M
Hello all,
Thanks
That's normal, the same happens for me with Eurocharged tune.
      12-05-2015, 09:12 AM   #5
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1047
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
Active Autowerks tune also creates noises and error messages during install process, but once you switch the vehicle off and reboot, everything clears up. I didn't have to cycle the car 4-5 times.
