      12-02-2015, 10:52 AM   #1
LastLong
LastLong's Avatar
Drives: Nothing
Air Filter: K&N or no?
Hi everyone,
What do you think about the air filter K&N for your BMW X5/X6 ?
Better or Cheaper than OEM from BMW Dealer? Or they have the same quality?
Thank you.
- 2015 F85 BMW X5M = SOLD
- 2012 E70 BMW X5 35i - M Sport = SOLD
- 2008 E71 BMW X6 35i - Sport Pack = SOLD
- 2007 E70 BMW X5 4.8i - Sport Pack = SOLD
- 2007 E70 BMW X5 30si - Sport Pack = SOLD
      12-02-2015, 11:21 AM   #2
socale39
Drives: 04 545i SMG
The problem with the K&N filters is that they have often been linked to faulting MAF sensors due to the excessive oil residue coating the sensor. Considering the negligible gains of just the filter change itself, I'd advise keeping it OEM and not having to worry about having potential issues.
      12-02-2015, 11:27 AM   #3
omgboost
Drives: 2012 X5 35i
I would use the stock intake filter. Gains aren't there and I read someone modded their 1 series N55 motor to upwards of 500hp and still uses the stock airbox/intake.
      12-03-2015, 08:36 AM   #4
racermp
racermp's Avatar
Drives: F30 330i
Try afe dry filter
      12-03-2015, 04:05 PM   #5
Cattivo
FDNY Engine 55
Cattivo's Avatar
Originally Posted by racermp View Post
Try afe dry filter
This
      12-03-2015, 07:02 PM   #6
Capnhook
Capnhook's Avatar
Drives: 2012 X5 35d
I've used k&n on 5 of the last 5 of my vehicles and not one has had issue with MAF. If you wanna shell out the $$ for basically nothing more than a filter you never have to replace (but DO have to clean), go for it.
      12-03-2015, 11:08 PM   #7
jrmccain
jrmccain's Avatar
Drives: 2022 M5C
Yeah, I've been using these filters for years, on my motorcycles as well, and have never had an issue. I personally think it's overstated and more urban legend than truth. Not to say its never happens, but if maintained properly, these filters will provide a lifetime of trouble free service. I would suspect the only time a MAF gets damaged is when the user goes overboard on the oil rather than lightly oiling the filter element.
      12-06-2015, 10:26 AM   #8
racermp
racermp's Avatar
Drives: F30 330i
Yea I've used k&n on my e90 and several other cars. Didn't have an issue except my first oeb that I wayyyy over oiled. Opps. Heheh. Well I never reoil these filters after I rinse them. I don't use the chemical to clean, just rinse.
If you do oil, do not oil the side that goes towards the throttle body. And lightly oil. If you are really worried, use the AFE air dry.
      12-06-2015, 06:09 PM   #9
omgboost
Drives: 2012 X5 35i
Any sound difference?
      12-08-2015, 01:30 PM   #10
LastLong
LastLong's Avatar
Drives: Nothing
I bought this K&N air filter:
What shoud I use to clean it up?
      12-08-2015, 01:46 PM   #11
Hugo L.
Drives: LGT, M3
K&N sells a kit that includes the cleaner fluid and the oil. 20$ or so.
      12-08-2015, 09:44 PM   #12
LastLong
LastLong's Avatar
Drives: Nothing
Is it a special product or can I use water to clean it up only?
      12-08-2015, 10:25 PM   #13
jrmccain
jrmccain's Avatar
Drives: 2022 M5C
The benefit of the K&N oil filter system is that you can reuse the filter element again and again. I know that many proclaim the hp gains, increased throttle note and many other benefits, but in my mind the greatest is its reusability. Once you buy a K&N,or any oil filter element, you should not have to ever buy a new air filter again. At desired intervals you can clean and re-oil the filter and you go on your way.
There may be some minimal hp gains with this type of filter but I doubt you'll notice. As far as exhaust note, I've found that these filters, coupled with a cold air intake, (one that foregoes all the OEM sound baffling), will produce a much louder sound. Wether or not you can get a cold air intake for the X5 I do not know. For the X5M, there isn't, as I know, that option.
Oh, your original question. Yes, the filter cleaner is completely water soluble. I spray the filter thoroughly, let it sit for 20-30 minutes and then rinse it under the hottest water I can get. I then let it dry for 24 hours or over night on a fan.
To re-oil all you do is lightly spray the oil on the filter. I don't spray oil on the intake side because I feel enough oil is absorbed throughout the entire filter that I would rather not risk over doing it. The element itself is cotton, so absorbing the oil is not an issue. It's really not that complicated, after the 2nd time you're a pro! Hope this helps.
Filter Maintenance Kit: http://www.amazon.com/gp/product/B00...hps_bw_g263_i1
      12-09-2015, 07:44 AM   #14
LastLong
LastLong's Avatar
Drives: Nothing
Great!! Thank you very much for these information.
