      09-09-2014, 08:47 AM   #1
bmwstve
Drives: BMW X6, MHD Stage 2
Wide tire options?
Just saw a good deal online on a set of rims for my X6
Front: 22x10 +40 offset
Rear: 22x11 +35 offset
1. Will these fit my X6?
or will the rims be too inside/outside of the fenders?
Rubbing issues?
2. What tires will be the best choice?
I understand that tires need to be of same diameter so that Xdrive wont be damaged.
Really like to have wide tires though but not too low profile to avoid pothole damage.
      09-09-2014, 12:46 PM   #2
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Ok I understand maybe wanting taller tire but wider ? what these come with is not wide enough ?
2022 X6MC - 2011 335D
      09-10-2014, 11:34 AM   #3
bmwstve
Any of these sizes available in the market? Any reputable brand will do:
Rear tires:
335/30/R22
345/30/R22
or
355/30/R22
I'm just concerned about the Pirelli's 335/25/R22 cause the sidewalls are quite thin and the rims might easily get damaged when I hit a pothole
      09-14-2014, 06:06 AM   #4
daytona1712
Indonesia
Drives: X6M
Hi...just put a set of 22" wheel n tire on my X6M with tire setting 285/30/22(F) and 335/25/22(R).My front size is different from other X6 here because most of them are 295/30/22.
I found that 285/30/22 diameter and rev/mile is almost the same with original setting compare to 295/30/22 eventhou I have to use different brand where Toyo for front and Pirelli for rear.
Rear tires:
335/30/R22
345/30/R22
or
355/30/R22
