      01-30-2018, 01:56 PM   #1
e70jane
e70jane's Avatar
Drives: bmw e70
X5 4.8l 35 faults detected, Cel and hesitation
2nd opinion needed from this forum..
Below is the detailed fault report for my 07 x5 4.8l. Been having a problem where the cel comes on and then car hesitates on acceleration. When I reset the ecu the car drives fine but for a little while and then cel comes back again. What is the problem?
INFO: ><
2018-01-29 19:16:10
BASE: E70
BUILD-YEAR: 2007
MODEL: X5 (E70) Automatic engine recognition (94)
ADDITIONAL OBD: OFF
FAULTS: 35
ECUs: 36
BATTERY: 11.6V
DEPTH: Normal communication
SPEED: normal
CONNECT: Fast Connection
VERSION: 11.1.2
DEVICE: >min's iPad< >iOS<
WIFI: >Carly Adapter v00<
ELM: >ELM327 v1.4 v21<
COM+: >YES<
0. Motor Control:
Engine / Motor:
- Fault: oelzustandssensor
- Code: 002EA0
- Fault: BSD message from intelligent battery sensor missing
- Code: 002EB8
- Fault: BSD message from the oil sensor is missing
- Code: 002EBC
- Fault: BSD-Nachricht vom Generator fehlt
- Code: 002EBD
- Fault: Local CAN communication 2
- Code: 002DDF
- Code: 002DDE
- Fault: CAN-Timeout VVT-Control unit
- Code: 002DDD
- Fault: PT-CAN communication error
- Code: 00CD8B
1. ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung:
ECU OK, no fault code
Dynamische Stabilitaets Kontrolle / DSC:
- Fault: Steering angle sensor
- Code: 006EC4
Hand brake / Feststellbremse (EMF):
2. Airbag:
Advanced Crash and Safety Management (ACSM):
- ECU not present/no answer
3. Transmission Control:
Transmission / Getriebe GS 19:
- Fault: :K-Can Bus off / SMG 3
- Code: 00CF37
- Fault: :K-Can Bus off / M-Drive
- Code: 00CF2B
Transmission / Getriebesteuerung:
- Fault: VGSG wheel Notlaufregelung activated. No DXC desired torque setting
- Code: 0055C3
- Fault: CAN message
- Code: 0055D0
4. Instrumentation:
Instrument cluster / Kombiinstrument:
Central info display / Zentrales Display:
- Fault: Energy Supply
- Code: 00A46B
Head-Up Display:
5. Light/Rain Control:
Rain/light sensor / Regen-Lichtsensor RLS:
High-beam / Fernlichtassistent:
6. Heating / AC:
Air conditioning / Klimaanlage:
- Fault: K-Can failure
- Code: 00E72F
- Fault: Power Management
- Code: 00E714
- Code: 00E729
AC front / Front Klimaanlage:
- Fault: Sensor ventilation Links
- Code: 00A1F2
- Fault: Fuhler ventilation right
- Code: 00A1F3
- Fault: Schichtungspoti Links
- Code: 00A1F4
- Fault: Schichtungspoti law
- Code: 00A1F5
- Code: 00E754
7. Immobilizer System:
CAS:
- Fault: CAS Supply Error
- Code: 00A0B2
- Fault: Input P N signal fault from EGS
- Code: 00A0B1
8. Park distance control / PDC:
Park Distance Control / PDC:
9. Sunroof / Roof:
Roof / Dach:
- Fault: SHD failure
- Code: 00A092
- Fault: ESH failure
- Code: 00A0A2
10. Audio / Navigation / Communication:
Multimedia-Changer / Wechsler:
Phone / Telefon:
HiFi-Verstaerker:
Tuner Antenna / Antenne:
Hybrid Radio USA:
Digital Satellite-Tuner USA:
Headphones / Kopfhoerer Schnittstelle:
Navigation:
CD-Changer / Wechsler:
Audio-System:
Video:
DAB:
11. Seats:
Backrest width / Lehnenbreiteverstellung:
Seats / Sitze:
Seats / Sitze:
Seats / Sitze:
Seats / Sitze:
12. Systems:
Junction Box Passenger / Beifahrer:
Fuel pump / Kraftstoffpumpe:
Tire pressure control / Reifendruck Kontrolle:
Passive Go System:
Car Communication Computer CCC:
MASK:
Rear-Monitor / Rueckfahrkamera:
- Code: 00A48B
- Fault: Energy saving mode is active
- Code: 00A811
- Fault: Power supply defective
- Code: 00A80D
- Fault: sorry, unknown DTC fault
- Code: 00A81B
- Code: 00A81A
Car Communication:
13. Anti-theft alarm system:
Theft alarm / Diebstahl Warnanlage:
- Fault: unknown fault
- Code: 009D45
- Fault: Information: back-up battery is discharged
- Code: 009338
14. Chassis:
Air suspension / Luftfederung:
Electronic damper / Elektronische Daempfer:
15. Body:
Automatisches Front Steering:
Trailer / Anhaenger:
Fussraummodul /FRM:
- Fault: Defective left brake light
- Code: 00A8B6
- Fault: Charge Controllers for extra battery deep discharge error in separating element / harness or secondary battery
- Code: 009CB5
EDC left front / vorne links:
EDC right front / vorne rechts:
EDC left rear / hinten links:
EDC right rear / hinten rechts:
16. Other:
Central Control / Zentrale Bedieneinheit:
      01-30-2018, 02:05 PM   #2
RichardR0404
Drives: 2013 BMW X5 35D
You might want to recharge your battery fully and check the spec on your alternator. My car have tons of faulty code after I keep driving my car while my battery is constantly at a very low level of charge.
      01-30-2018, 03:28 PM   #3
e70jane
e70jane's Avatar
Drives: bmw e70
Someone else recommended the same solution. I did replace the battery a week ago and looks as though the ecu is still registered under old data.
