      05-18-2016, 06:30 AM   #1
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Drives: 2019 M5 Competition (F90)
Slow cold start
I tried to search these forums for my topic, without any luck (I also did not try very hard). My wife's X70 has been having really slow cold starts for weeks now. The car does start, but it does feel like it will not one of these days. It is at the dealer now getting serviced. They had thought that it was a bad grounding strap, then maybe the fuel pump, now they are not sure. Has anyone else encountered this?
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired)
2008 E60 528i - Space Grey (retired)
2002 E46 325i - Space Grey (retired)
1999 E46 328i - Orient Blue (retired)
      05-18-2016, 07:03 AM   #2
F06msportmia
F06msportmia's Avatar
Yes, I had the same issue until one day the car didnt want to turn over anymore.
Had to get the car towed back home and went to work on the starter. Prior to changing the starter I had checked the battery and it was 100%. No issue there.
The starter is $280 at the dealer and they make you turn in the old one. I did this DIY, and it was a difficult job. Unless you feel comfortable in the engine bay I wouldn't do it.
Good luck and let me know if you have any questions.
      05-18-2016, 07:11 AM   #3
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Thanks e70msportmia the battery was replaced about a year ago. I'll check on the starter.
      05-18-2016, 07:36 AM   #4
slobo7x
Drives: 2016 550 F10
If you can post some more info that would be great. Does starter replacement require intake manifold removal on 3.0 X5?
Thanks
      05-18-2016, 07:54 AM   #5
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Thanks
I would have to leave the answer to that question to e70msportmia as I am completely lost when it comes to under the hood.
      05-18-2016, 10:26 AM   #6
F06msportmia
Thanks
That is correct... You have to remove the intake manifold. Its literally in the middle of the engine tucked away.
      05-18-2016, 12:40 PM   #7
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Well, I got a confusing explaination today from my SA. It is not the starter and is also not the fuel pump. Apparently there is a engine priming pump that they think is the problem and to replace it would cost $1750. I decided to continue to deal with the slow cold starts for now as I am not convinced what the problem really is.
      05-18-2016, 01:45 PM   #8
F06msportmia
I call bull shit to your SA! I never trust what they say, they see you walk in and Cha Ching!
Those are my 2 cents! Good luck.
