      02-12-2023, 12:34 PM   #1
nitewolf720z
nitewolf720z's Avatar
12
Drives: 12 BMW X5 xDrive35i
2016 BMW X5 35i  [0.00]
2012 BMW x5  [0.00]
2012 BMW X5  [0.00]
'12 X5 xDrive35i is starting but isnt cranking
I recently replaced the Fuel rail pressure sensor, Transmission harness, and Exhaust camshaft position sensor and also a make shift ground wire from autozone. Few weeks ago my car I left my car idling and it suddenly shut off then I thought to my self it can be the battery so I towed it back home bought a battery next day registered it and then it was still the same issue no crank but only starts. Everytime I try turning it on I can hear the starter click once and no crank at all. Also I checked if my engine was seized with a breaker bar and thankfully it was not seized. If you guys have any idea what it can be please let me know!
      02-12-2023, 10:54 PM   #2
Serf27
Serf27's Avatar
2851
Drives: 335i
Do you have any errors codes?
      02-12-2023, 10:55 PM   #3
nitewolf720z
12
2012 BMW x5  [0.00]
2012 BMW X5  [0.00]
No error code I was wondering if it can be starter?
      02-13-2023, 12:05 AM   #4
Serf27
Serf27's Avatar
2851
Drives: 335i
Bad starter will trigger an error code.
Was it hard to turn the engine by hand?
I had a bad alternator bearing prevent the engine from turning over a few months ago.
I HAVE NOT dealt with this personally, but could it be possible that a ground strap from engine to body is bad?
      02-13-2023, 12:07 AM   #5
nitewolf720z
12
2012 BMW x5  [0.00]
2012 BMW X5  [0.00]
The ground strap from the engine is bad! And no the engine was pretty easy to move with the breaker bar
