      04-10-2018, 01:51 PM   #1
ISMERX5
ISMERX5's Avatar
Drives: 2012 BMW X5 35D
22inch Rims Tire Size
Is there any other size i can use other than 295/30/22 and 335/25/22 to not confuse the xdrive on my 2012 E70? I don't want to use those skinny tires i want my look a little thicker
      04-10-2018, 02:43 PM   #2
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
Really helpful tool to determine the right size for your 22 inch wheels.
https://tiresize.com/calculator/
Just make sure the rolling diameter of both sizes match. if they dont, you will blow your transfer case
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
m5james431.00
      04-12-2018, 01:07 PM   #3
WuCreW
Drives: 2011 X5 3.5L
I run those with my X5, but you can also run 295/35/22 (-3.74% from OEM) and go 305(or 315)/30/22 (+0.56 % from OEM) in the rears for little more tire.
Your call
      04-13-2018, 07:26 PM   #4
Cultusking
Drives: 2010 BMW X5d
I run 265/35-22 and 305/30-22 This is virtually identical sizing to each other in height and also virtually the same diameter as the stock tires so the speedo isn't out
