      01-06-2014, 05:06 PM   #1
kk-bmw
Drives: 2013 X5 35i Premium
Creaking Tailgate
I recently took my 2013 X5 in to have a creaking noise looked at. At any speed, the slightest bumps in the road make a very noticeable creak sound from the rear of the vehicle. The service center said they took all the trunk panels off and tightened them. They said they drove the car and the noise went away. I picked up the car and immediately noticed the noise. I plan on bringing the car back, but didn't return right away because the only workers remaining at the time were receptionists.
Has anyone had issues with noises coming from the trunk? I think it's the tailgate, as if it's shifting around when driving.
Thanks,
kk-bmw
      01-06-2014, 05:46 PM   #2
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
Go in the back pull down your second row seats and put electric black tape around the metal hook where the seats latch and you it will go away
      01-06-2014, 05:46 PM   #3
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
Known issue. I had multiple visits for same issue, to no avail.
In the end, I myself realigned the upper and lower tailgates and the creak went away. The tailgates were misaligned from factory, even visible with naked eye.
In addition, I have isolation tape wrapped to the center ring that uppper tailgate attaches to when closed. That took care of metal clunk noise during cornering.
Look here
      01-06-2014, 07:39 PM   #4
zarathustra
Drives: 2013 X5 5.0 M sport
Hi have the same exact problem and its annoying the hell out of me.
I cant re-create the sound by hitting the back seats or panels. I hear it only during cornering and bumps.
      01-06-2014, 09:02 PM   #5
///SAL
///SAL's Avatar
Doesn't hurt to try lol
      01-06-2014, 09:45 PM   #6
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
I think I love you.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      01-06-2014, 11:18 PM   #7
kk-bmw
Thanks for the suggestions. I will try the electrical tape with the seat latches and see what happens. If it's not fixed, I'll have my dealer take another look at it on Wednesday when my X5 goes in for the third time because of this creak and limp mode (another thread coming on that!)
I'll keep you guys updated.
      01-07-2014, 12:40 AM   #8
fireroasted
Drives: X5
Look here
Thanks. I think I have the alignment issue because my sound is that metal clunk when twisting the body. Like through a driveway maybe. Rattles drive me nuts, and my other car is an Evo, which is only massively ironic!
      01-07-2014, 02:47 AM   #9
KrisHorton
Drives: E70 X5M and E60 M5
When I took it to the dealership they couldn't figure it out and wrote it off as an intermittent issue.
I ended up taking it to an independent shop (Coast Motorwerke in Huntington Beach) and they knew right away what the issue was. Their remedy was putting a special grease on the tailgate and hatch latches. It did the trick and the noise went away.
      01-07-2014, 02:58 AM   #10
enzoleo
Drives: X5M
i solved my tailgate creak by removing bottom tailgate plastic cover, removing the metal casing that holds the catch mechanism(motor) that pulls the upper tailgate shut and pushing the catch inwards a few mm and tightening everything up. i wrap every single metal latch including those that hold the back seats with heavy duty duct tape since i dont have felt tape. silence at last and only creak during body flex. i have sensitive ears and i think all the noise problems that the e70 have can be solved! good luck!
      01-07-2014, 03:19 PM   #11
kk-bmw
I temporarily fixed my creaking issue. I put electrical tape around the latches where both the upper and lower portions of the tailgate close. Hopefully my dealer will have a more permanent solution but this works for now.
Thanks for the help, guys!
      01-07-2014, 05:32 PM   #12
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
I have a similar noise in my passenger front door. It drives. me. insane.
I've not yet taken it to the dealer to have it looked at. Ugh.
      02-03-2014, 10:28 AM   #13
Joyaant911
Drives: 2007 x5
Can anybody post pics of where exactly you installed black tape?? Would be helpful thanks
      02-03-2014, 11:57 AM   #14
serge1
Drives: X5 35d
Wrap the tape around this ring
      02-07-2014, 10:46 AM   #15
Capnhook
Capnhook's Avatar
Drives: 2012 X5 35d
I actually wrapped a thin layer of felt carpeting, maybe 1/16" thick by the width of the latch and secured it with an adhesive, around the latch. This approach has seriously lessened the frequency of the creaking. Now it's a couple times a day, versus over any bumps in the road, with a lot less intensity!
It seems to me to be caused by the exceptional tolerances allowed in this latch/joint, and with any flexing/twisting of the vehicle the sound is attenuated in this region.
      02-14-2014, 12:13 PM   #16
migo1980
Drives: 335i
I also had some crazy creaking tailgate and rear seats. The dealer adjusted/tightened stuff on the tailgate and the rear seats no noise now.
      02-15-2014, 08:20 PM   #17
JJLEV
Drives: 2011 X5 35d
My tailgate was creaking terribly to the point where I was losing my mind. Dealer was zero help. Tried the electrical tape on the latch repair as recommended in this thread. Creaking is GONE! ...thanks guys.
      05-24-2016, 11:16 PM   #18
zachzay
Drives: 2016 X5 35i
Wanting to bring this thread back to life. Having serious popping sound issues. Can anyone give a concise solution to this problem? Much much appreciated!!
      05-26-2016, 09:15 AM   #19
Capnhook
Capnhook's Avatar
Drives: 2012 X5 35d
Curious if you tried my advice in post #15 above. It did lessen the frequency of the sounds in our '12 35d. But because of the large single piece of plastic covering the rear lower tailgate, I'm assuming the plastic just is flexing with the vehicle suspension. I don't see a cure-all for this other than covering the plastics with carpet.
      06-02-2016, 10:30 PM   #20
zachzay
Drives: 2016 X5 35i
I have same issue in my 2016 X5. Where are these seat latches? How do I find them?
      06-02-2016, 10:32 PM   #21
zachzay
Drives: 2016 X5 35i
How did you get to the latch? I dot quite understand by the picture. All help appreciated. Thanks
      06-11-2016, 07:31 AM   #22
heatmizr
Drives: E70 X5 50i M-Sport
Have you looked behind the seats?? If you can't find them you might consider taking the vehicle to a dealer for service.
