      12-20-2013, 09:23 AM   #1
Apaolo
Drives: 2009 BMW X6 5.0i xDrive
Painted and replaced front grilles to black on the X6
Hey guys,
So I've had my x6 5.0i for a few weeks now and I've already painted and replaced all my front grilles and deleted the license plate. What do you think!?
      12-20-2013, 09:24 AM   #2
Apaolo
      12-20-2013, 02:49 PM   #3
Deda
Deda's Avatar
Croatia
563
Drives: BMW M5 comp
Nice!👍
      12-22-2013, 01:21 AM   #4
RickNY
Drives: 2014 X6 50i
Looking good so far. Next up change out those orange reflectors.
      12-22-2013, 09:55 AM   #5
bigozuk
Drives: BMW X5 F15 2016 Sapphire black
i've just order an X6 thats exactly the same colour as yours, and painting the mesh is the first mod i'll be doing - thanks for the photos.
What about painting the under side skid plate as well?
      12-22-2013, 02:33 PM   #6
Apaolo
I actually didn't paint the mesh BMW sells those two center ones fairly cheaply. The hardest part was the installation. The only ones I painted were the fog lamps ones. I'm undecided about the skid plate you barely see it so I dont know if I want to deal with it.
      12-25-2013, 04:03 AM   #7
bigozuk
how easy was the fog light trim to remove? does it just pull off or do you need to remove the entire mesh assembly first then separate the trim from the mesh?
      12-25-2013, 01:33 PM   #8
bigozuk
I ordered up a set of the black grilles you mentioned, so these should be with me shortly - the trim that is anoying me most (and i've only had the car three days) is the wheel arch and side sills - i hate these being black so i'm thinking of getting these sprayed to match the colour of the car. Anyone one else already painted those parts?
      12-26-2013, 07:09 AM   #9
Apaolo
You literally just have to stick your fingers in the mesh and pull it out, the whole thing just snaps in and out. Then the silver part snaps on and off as well, very easy.
      12-26-2013, 07:12 AM   #10
Apaolo
I was thinking the same thing but those are a little more complicated to get off. I was thinking of just buying the m sport package and just installing that instead vs trying to get everything painted on this one. Make sure you have a good shop paint those as well, I own a body shop and I know it's a pain to paint those textured painted peices without them starting to peel and chip. Make sure they put some kind of primer first then paint so it grabs.
      12-26-2013, 12:29 PM   #11
bigozuk
[QUOTE=Apaolo;15174691]I was thinking of just buying the m sport package and just installing that QUOTE]
what does the M Sport package consist of?
      01-06-2014, 01:16 PM   #12
bigozuk
how do you get the bottom grille off the car? the small upper one was easy, but i cant see any way of getting the bottom one off.
      01-07-2014, 12:41 PM   #13
badblkX6
Drives: 2014 X6 35i
Here you go! This was my method and worked pretty damn good. Hope this helps!
http://www.xbimmers.com/forums/showthread.php?t=892977
      01-07-2014, 02:00 PM   #14
bigozuk
perfect, thanks
      01-11-2014, 02:43 PM   #15
bigozuk
grilles changed
i replaced my front grilles today - what a nightmare job it is to change the bottom grille..!
      01-13-2014, 08:58 AM   #16
badblkX6
Drives: 2014 X6 35i
No problem! That's an awesome color combo. Good choice swapping out for black grilles.
      01-13-2014, 10:31 AM   #17
Phorte
Australia
Drives: E60 M5
what did you use to paint the bit around the fog lamps and how long did it take once removed?
      01-27-2014, 01:26 AM   #18
6lacksheep
6lacksheep's Avatar
Drives: 2016 BMW X6M
Hey man, did you plasti dip the plastic around the fog lamps? Im about to do mine, just wondering how you went at it
      01-31-2014, 10:49 AM   #19
bigozuk
no I just sprayed them with matt black paint, easy job
      01-31-2014, 01:55 PM   #20
Z@T
Pilot
Z@T's Avatar
Drives: M3, Vantage, 997, ModelX
Very nice!
      03-18-2014, 12:46 PM   #21
Andrew@SW
Drives: BMW 135i
Nice!
      03-31-2014, 10:28 PM   #22
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
how did you get the front grilles (kidney grilles) out? on my old 330 it was just pull. but these seem more complicated.
"Teach the ignorant. Ignore the stupid."
