      03-04-2023, 02:59 AM   #1
Emad
Drives: BMW X6 35i 2013
Exclamation 2013 BMW X6 -coolent issue - PLEASE HELP!
Hi Guys,
I faced an issue with the oil mixing with the coolent last week and got the gasket oil filter, oil cooler and oil changed last week and now i had a coolent low sign and when i checked there was a leakage from the coolent (milky brown color), not sure what the issue is. Has someone faced a similar issue?
Kindly advise
Attached photos for reference
      03-04-2023, 08:38 AM   #2
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
Oil and coolant mixing is usually a sign of a blown head gasket or warped heads. I’d suggest trying a leak down test of the cylinders. If they compression is low then it’s likely the head gasket or warped heads.
When replacing the head gaskets I’d also suggest having the heads rebuilt, checked for flatness and milled if needed.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
