      11-11-2014, 02:16 PM   #1
Klimo
Drives: 2012 X5 50i
Which wheel size?
I am order new winter wheels and want to run 19/255s all the way around.
Should I be getting the 19x9 or 19x10 rim?
Car is '12 50i with fender flares.
Thanks!
      11-11-2014, 03:10 PM   #2
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Do you have OEM 19" wheels? Just get winter tires that will fit those.
      11-11-2014, 03:12 PM   #3
witz323
Drives: 2020 M8 Comp
You'll probably want to go with a 17 or 18 for winter use. Lots of affordable tire options in that diameter.
2014 Cayenne GTS
2009 C4S Cab
2004 Dodge Viper
2020 M8comp
      11-11-2014, 03:35 PM   #4
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
If you have 20's on your x5 now, I would recommend 19's. The 18's feel really soft compared to 20's.
I don't believe that 17's will even fit on the e70
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      11-11-2014, 04:34 PM   #5
P1
P1's Avatar
11572
The ride going from 20" RFTs to 18" snow tires was noticably more confortable.
      11-12-2014, 04:17 PM   #6
Klimo
Drives: 2012 X5 50i
Umm ok. No answer to my question yet. lol
Does the 255 tire fit the 19x9 rim or the 19x10 rim? I plan on running 255 at all 4 corners.
      11-12-2014, 04:43 PM   #7
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
it will fit the 9, 10's prob gonna be a stretch
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      11-13-2014, 10:18 AM   #8
MRV99
MRV99's Avatar
I run style 211's for my winters and they are 9.0 width. Most of the 255 tires are spec'd for 7-9 inch rims.
--RIP--
      11-13-2014, 10:46 AM   #9
Klimo
Drives: 2012 X5 50i
Perfect. Thanks.
I just wanted to double check the fitment of the 19x9s im ordering. 48mm offset. That should be good at all 4 corners, right?
      11-13-2014, 03:21 PM   #10
Klimo
Drives: 2012 X5 50i
What offset do you have for front and rear?
      11-14-2014, 02:59 PM   #11
Klimo
Drives: 2012 X5 50i
I am just trying to confirm fitment of 19x9" 48et wheels for all 4 corners of my '12 X5. Do I need a different offset for the rear set or will those work all the way around?
Having trouble getting this confirmed. Thanks
      11-14-2014, 09:31 PM   #12
Da M3nace
Da M3nace's Avatar
25
Drives: 04 M3
Lol. I feel your pain.
      11-14-2014, 10:31 PM   #13
MRV99
MRV99's Avatar
I have et48's all around. Exactly what came OEM on my 2007 e70 which I turned into my winter set
--RIP--
      11-17-2014, 09:41 AM   #14
Klimo
Drives: 2012 X5 50i
awesome. Thanks.
Ordering 4 19x9 et 48 wheels today.
