08-06-2013, 12:20 PM | #1 |
11817
Rep 23,187
x5 brake pads?
looking for a set of front brake pads and unsure what my options are. havent found anything that exciting yet. x5 is a 2007 3.0 and thought that stoptech was going to be making a oem replacement st pad but no luck i guess. anyone have suggestions. have seen posi-quiet as well but dont know that brand.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
08-14-2013, 09:14 PM | #2 |
11817
Rep 23,187
little help here!!
08-14-2013, 09:21 PM | #3 |
Rep 6,125
Hawk HPS, Akebono Euro Ceramic and Hawk Performance Ceramic are your options (they all make the f/r pads for 07 X5 3.0si).
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
08-14-2013, 09:32 PM | #4 |
11817
Rep 23,187
thank you sir.
08-20-2013, 12:34 PM | #5 |
11817
Rep 23,187
thanks ordered a set of the hawk hps for the front. havent used before but should be fine for this application.
08-20-2013, 12:53 PM | #6 | |
Rep 6,125
But slightly less initial bite compare to OEM pads (BMW OEM brakes are a lot more sensitive and more initial bites than other cars) but you'll get used to it. With extremely less amount dust and easy to clean dust (they're not like OEM since different compound), you'll not regret it.
08-20-2013, 01:24 PM | #7 | |
11817
Rep 23,187
08-23-2013, 02:08 PM | #8 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
Brembo or Bosch
You can brembo or Bosch rotors and pads on eBay for a reasonable cost.
I bought Brembo rotors and pads for the rear and they ran $225.00 total. Make sure you get the spring set. Beck and Arnley make a nice set for relatively cheap. |
08-23-2013, 02:17 PM | #9 |
11817
Rep 23,187
Only needed front pads and got hawk hps. I'm cringing thinking what sort of rotor pad combo you got for 225 bucks. Maybe brumbo instead of brembo?
