      08-14-2012, 08:52 PM   #1
provatocj
Drives: 2009 X6
2013 X5 50i w/ M Perf Package - 0-60?
Anyone know the 0-60 on a '13 X5 50i with the M Performance package? Thanks.
      08-15-2012, 01:32 PM   #2
ndabunka
Drives: 2012 X5 35d Sport Black/Black
Do you mean a X5M or an X5 with the M cosmetic package?
The TRUE M has a 4.5 second zero-to-sixty performance numbers with the 440 HP & 500ft/lbs of torque. The X5 5.0i with the M-Sport cosmetics does not break the 5 second barrier
      08-15-2012, 02:56 PM   #3
Blitzblau
Field Marshall
Blitzblau's Avatar
Drives: 2012 Black Saph Metallic X5M
All I know is it has an additional 40hp and 50lb/ft
for 440 HP and 500lb/ft.
Must be pretty quick....but for all that money...why not get the M?
It seems like a no brainer for me... I fuggin love my M. Wouldn't go any other way.
2008 Interlagos Blue E90 M3 (Retired)
2012 Black Sapphire Metallic X5 M (Velos Designwerks Tune, LUX H8 V3 Angel Eyes, Black Sapphire Metallic Kidneys and Roundels, M floor mats
2009 Black Cadillac Escalade Hybrid
      08-15-2012, 04:56 PM   #4
provatocj
Drives: 2009 X6
Thanks fellow Charlotte, NC. I was talking about the 0-60 on the X5 50i with the "M Performance" package that adds 40HP to the base 50i. The monster X5M pumps out 555HP and runs 0-60 in the mid-4's (though I read one test where is was running low 4's). The standard 50i is supposed to be mid-5s, so I'd guess low 5's with the M Performance Package (MPP)? Who knows. Curious if anyone has read any actual tests. Thanks.
      08-15-2012, 04:57 PM   #5
provatocj
Drives: 2009 X6
I know...would have loved the X5M...but by the time I spec'd it out the way I wanted it....just too far over my budget. One day!
      08-15-2012, 08:07 PM   #6
Mark_G
Drives: 2020 X3M competition
That's not correct...
The X5M has 555hp and does 0-60 in 4 seconds flat with launch control.
The X5 50i has 400 hp and does 0-60 in 4.8.
The X5 with the M-sport package has 440 hp and hasn't been tested in mags but probably hits 60 in about 4.5 seconds.
And the X5 50i with Dinan stage 1 or 2 has around 500 hp and probably gets to 60 in around 4.2-4.3. I haven't tested but I've had both this and the X5M and the off-the-line performance is very close.
      08-15-2012, 08:14 PM   #7
provatocj
Drives: 2009 X6
Thanks Mark. Curious, where are you seeing the 50i doing 4.8? That's impressive. It's offically listed at 5.3. Would like to read the test. Appreciate it.
      08-15-2012, 08:28 PM   #8
poloka
Drives: 540xi
X5M 0-60 4.5 sec with 555 HP
X5 + M package 0-60 5.3 sec with 440 HP
http://www.bmwusa.com/Standard/Content/Vehicles/2013/M/X5M/Features_and_Specs/default.aspx?from=/Standard/Content/Vehicles/2013/M/X5M/Features_and_Specs.aspx&return=/Standard/Content/Vehicles/2013/M/X5M/Features_and_Specs.aspx
http://www.bmwusa.com/standard/content/vehicles/2013/x5/xdrive50i/features_and_specs/default.aspx
BMW CCA: 501218
Current owned:
2018 540xi MSport
Previously owned:
2015 650xi Gran Coupe MSport
2011 X5 50xi MSport
      08-15-2012, 09:03 PM   #9
provatocj
Drives: 2009 X6
Originally Posted by poloka View Post
Thanks, but 5.3s is the official time for the base 50i (400HP) without the M Performance package (+40HP). And those times are proven conservative.
      08-15-2012, 09:05 PM   #10
Mark_G
Those are official BMW numbers, but real world tests have been better.
http://www.caranddriver.com/comparis...on-test-review
This is the X6 50i, but it's with the old 6-speed transmission which had less aggressive gearing.
http://www.roadandtrack.com/content/...ve50i_data.pdf
AKA Tahoe M3
      08-15-2012, 09:10 PM   #11
provatocj
Drives: 2009 X6
AKA Tahoe M3
Thanks Mark!
      08-15-2012, 09:53 PM   #12
ndabunka
BMW seems to have more options than I realized. I am sifting through the X5, X6 , M variants & even diesel variants so you can see that I am completely confused...LOL
      08-15-2012, 10:05 PM   #13
poloka
Drives: 540xi
You on the fence to whether or not to get X5M? I know I am.
BMW CCA: 501218
Current owned:
2018 540xi MSport
Previously owned:
2011 X5 50xi MSport
      08-15-2012, 11:15 PM   #14
Biff Grissel
stankmouth
Biff Grissel's Avatar
Drives: fun
u wont regret it, i guarantee it.
      08-16-2012, 02:56 AM   #15
mrmomo313
mrmomo313's Avatar
Drives: M6 Gran Coupe
+1
      08-16-2012, 06:46 AM   #16
poloka
Drives: 540xi
I know more HP is more fun but what else in the M do you like that is not on the standard X5?
BMW CCA: 501218
Current owned:
2018 540xi MSport
Previously owned:
2011 X5 50xi MSport
      08-16-2012, 09:46 AM   #17
Blitzblau
Field Marshall
Blitzblau's Avatar
Just an FYI...BMW is very liberal with the numbers and the X5M tested at 4.07 seconds on the first of 20+ consecutive runs and was still mid 4's at the 22nd (i believe), which is where they came up with the mid 4's for 0-62 time. This is stock as well.
I would guess that I can run 3.9 with my tune before heat soak. exfyvem is probably even faster with downpipes and exhaust.
      08-16-2012, 09:59 AM   #18
Blitzblau
Field Marshall
Blitzblau's Avatar
http://www.thetruthaboutcars.com/201...-2012-bmw-x5m/
It was actually 4.05 seconds and 4.51 on the 25th
      08-18-2012, 03:50 PM   #19
jbkonis
Drives: 17 ZCP M3, 15 X5M
X5 M and don't look back. Might as well go all in so there's no room for regret.
      08-18-2012, 04:05 PM   #20
TahoeM3
Drives: F-type R, GTR, X5 50i
The M is definitely awesome, but gets horrendous gas mileage. If you drive a lot you should take that into consideration. When I had mine I was filling up every other day. With the 50i and the 8-spd transmission I get about double the range even with the Dinan chip.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black
2022 BMW X5M MBB/SO
Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,...
      08-18-2012, 08:06 PM   #21
provatocj
Drives: 2009 X6
Thanks guys. Really appreciate all the info. In the end, the 50i lined up with my budget. M Sport, M Performance, Premium and Tech packages. Very quick. Tons of torque is perfect. Check it out....
      08-18-2012, 10:22 PM   #22
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
Nice. I have a similar car, minus the m package. Going with the Dinan chip in a few weeks. Nice to hear the feedback about it performance wise.
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
