      07-11-2013, 05:54 PM   #1
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
third connector on BMW individual audio amplifier
I have a BMW individual audio power amplifier. There are four connectors. One is 2-pin (most bus) connector one in, one out. This is clear. What are the four tiny pins next to it for? One is 20-pin speaker output (analog) connector with first two pins used for power +12V and GND. What is the fourth connector for? The one with 2-pins to the left of the 20-pin speaker connector?
      07-14-2013, 07:31 AM   #2
igorbmwx6
igorbmwx6's Avatar
OK, so the 2-pin connector to the left of the 20-pin connector is a +12V and GND (power connector). Does anyone know what the BMW part# of this connector or where can I purchase one from?
      07-30-2013, 04:58 PM   #3
nickspring
Drives: X5 E70
hi, maybe this page will be useful for you
http://bmwtools.info/viewtopic.php?f...p=59109#p59109
1) 2 pins power connector you don't need. You should use 10 a 20 pin in the big main connector
2) 4 pins in the MOST socket you don't need, only jumper for 1 and 2 pins (see page)
