12-12-2008, 11:31 AM | #1 |
Rep 71
No Start
I have the Comfort Access and noticed that if the car is not used for about 1 week when I come to start it using the Start button the engine won't turn on immediately. Only the electronics and AC turn on. I have to hit the Start button several times before the engine starts. Any idea?
12-12-2008, 04:03 PM | #2 |
Rep 154
I have noticed this once or twice. No relation to the 1 week of not using the car. My car is only two weeks old and I thought I was just not pushing the button down hard enough. The VW keyless entry on my previous vehicle had a feature that if you pushed the button half way, it would turn accessories on but car would not start. The one or two times my car did this I just pushed it again and it started. Please advise if you find any more.
Best, Brian |
12-12-2008, 05:06 PM | #3 |
Rep 256
There is an interlock that stops the car from starting if you don't have your foot on the brake. You could test that if you have some way to see if your brake lights are on while you are pressing the starter. Could be the brake light switch. Just an idea.
12-13-2008, 12:53 AM | #4 | |
Rep 683
No start
Do u have the repair code of the upgrade from ur work order? Thanx. |
12-13-2008, 04:24 AM | #5 |
Rep 71
Interesting suggestion regarding the brake light. I'll have to check next time.
Not too sure if this is related to the recall I had which was 6199000 (I think this number is unique to the dealer and not a BMW number) Re-call Campaign Program Control Unit Power Drop. |
12-13-2008, 12:15 PM | #6 | |
Rep 1,209
1. The push button is faulty. 2. The brake switch is faulty and the car does not think the brake is depressed. 3. The Shifter is faulty and the car does not believe it is in park. Does it make a difference if the fob is inserted in the slot or not?
2011 535i
2008 VW GTI |
12-13-2008, 02:58 PM | #7 |
Rep 71
Inserting the key doesn't make a difference. In my case, it doesn't happen when I drive everyday; only when left parked for about a week. This leads me to think it may be battery related.
12-17-2008, 09:50 PM | #9 | |
Rep 683
No start
Does your digital clock need resetting when u have the start problem? or the read out has no problem? I thought your dealer fixed some power drop problem for u. |
12-18-2008, 10:52 AM | #10 |
Live for today tomorrow never comes
1988
Rep 9,498
Very good piont, I have had no such problems with mine however.
12-18-2008, 01:04 PM | #11 |
Rep 71
Clock is fine - no need to reset. Not sure what the power drop that the dealer fixed was for. Might not be related. I don't think the issue is worth taking it into the dealer. I usually have bad experiences when sending cars for service. Most of the times they come back with the small door dents. I only send the car to service if it is for something major or a scheduled maintenance.
