08-03-2019, 05:43 PM | #1 |
Rep 2,736
Hello folks, selling my F86 style M wheel It's a fully loaded wheel with heat and vibro motor in it. Car systems can make a custom map for you for M functions. They made mine run heat and recirculate from the buttons, the module also supports paddles. Cruise control is also supported to the steering wheel and you can remove the stalk if you so wish. The airbag harness has already been adapted to fit to the e70 e71 column clock spring and is basically plug and play. You will need to call carsystems to get a new module harness as each truck is specific and may need different harness depending on options and ECU. Asking $1500 for the whole thing. Over 3k new. Not including module. If local I will install for you. |
08-04-2019, 12:41 AM | #2 | |
Rep 69
08-04-2019, 01:38 AM | #3 | ||
Rep 2,736
Luckily my insurance sided with me and found the dealer negligent. Was very sad to have to part her out! |
08-04-2019, 02:25 PM | #4 |
Rep 99
To anyone with an x5m, this statement is ONLY TRUE IF you also have the NBT retrofit. See page 15 of the module manual (attached) for more information. Otherwise, you will lose the use of M buttons on wheel. Folks with regular e70, have at it! Sorry to hear about your car. GLWS! |
08-05-2019, 06:33 AM | #6 |
Rep 3,151
Very unfortunate they cant get the M button sorted out or i would have considered this retrofit for the X5M. Your setup looks Mint. GLWS.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
08-05-2019, 01:51 PM | #8 |
Rep 2,736
