08-29-2013, 07:19 PM | #1 |
Rep 7,902
Enkei | Racing Revolution RS05-RR | New 2013 Model | Concave Profile
Racing Revolution RS05-RR Light Weight Wheel
Adapting concave style while inheriting the ENKEI racing spirits. Sparkle Silver Matte Dark Gunmetallic Fitment & Size: 18x8.5 ET35 18x9 ET50 18x9.5 ET35 18x9.5 ET22 18x10.5 ET23 18x11 ET30 We are expecting shipment early to mid Sep, pre order yours today! * MAT Technology * Clears BBK * Hub-Centric * Spacer not required * Light Weight Application MAT Technology Enkei developed a new manufacturing process to produce the next aluminum wheel generation. The Most Advanced Technology (M.A.T) combines one-piece cast wheel technology with a rim forming technology called spinning process. Using this new technology of casting and rim forming by M.A.T process, is critical to improve drastically the material property and strength of the wheels. Rim-Rolled technology shapes the rim to improve material elongation withoutsacrificing the wheels hardness. SPEC-E All Enkei wheels are engineered to pass rigorous testing. In fact, Enkei established its own test standard called “Spec-E,” which is tougher than JWL requirements. Enkei’s Spec-E test setting requires a higher drop point in the impact test and 20% more cycles for the rotary bending fatigue and dynamic radial fatigue tests than JWL standards.The Spec-E represents Enkei’s confidence in its technology and quality of Enkei wheels. |
08-29-2013, 08:47 PM | #2 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
18x8.5 ET35
18x9 ET50 I would love to see these on a 135i. Rear would be fine, front is pretty agressive though. |
09-01-2013, 07:40 PM | #5 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
None of these will fit stock suspension in the fronts lol
09-01-2013, 08:27 PM | #6 |
Rep 7,902
09-02-2013, 09:07 PM | #8 |
Rep 7,902
09-24-2014, 05:41 AM | #14 |
Rep 7,902
09-24-2014, 10:25 AM | #15 |
NOOOOB
9
Rep 192
but itd still fit right? a little fender rolling wnt kill
A COMPLETELY STOCK CAR!
09-24-2014, 11:19 AM | #16 |
Rep 7,902
10-11-2014, 11:25 PM | #22 |
all day
48
Rep 1,181
Drives: 2012 135i
Also interested in the 18x8.5 +35 / 18x9 to 782233.
BTW I run 19x8.5 +35 235/30 with lots of fender work and -2.o camber |
Tags |
enkei wheels, jdm wheels, rims, rs05-rr, rs05rr |
