      11-29-2014, 11:06 AM   #1
///Mpower///
Sergeant
///Mpower///'s Avatar
Drives: Spiritedly
The issue with non-staggered snow tires on X5M
So, after much research and countless conversations with Tire Rack, my SA, and a few indy BMW mechanics, the only common thread on the topic of "to stagger or not to stagger" is as follows:
Do NOT stagger. Keep all 4 square and do NOT use spacers to move the rears out flush with the body. The logic behind this is that if you stagger, your rear tires are hitting fresh snow that the fronts have not packed, flattened, or otherwise moved, and they're essentially plowing. Similar reasoning when it comes to using spacers to move the rears out, since they won't be perfectly aligned with the fronts.
Does everyone agree with this? I'm still not completely sold on the concept.
Thoughts?
_______________
///M
'16 535i Xdrive Msport
'13 M5 - Singapore Gray, Black Ext. Napa, Dinan FF Exhaust, much more to follow.
'12 X5 M - Carbon blk, Cinnamon interior <retired>
      11-29-2014, 12:35 PM   #2
SchaumerMol
SchaumerMol's Avatar
Drives: 2020 X7 M50
With AWD drive, why would it matter which axis is "plowing"? With rear wheel drive I'd somewhat agree...
      11-29-2014, 12:42 PM   #3
retusn
retusn's Avatar
Drives: 2013 X5M
I am on my third year with the staggered stock size set up and not a bit of problem or concern.
2013 E70 X5M
2011 E92 M3 traded in, 2009 CTSV LEMON, 2008 Z06 Lemon Law, 2007 Z06 Dealer butcher, 2004 Z06 (Sold)
1996 GrandSport (sold), 1996 Impala SS (Sold)
      11-29-2014, 06:22 PM   #4
Rez90
Drives: 2010 X5M
i have Motivo's on my X5M and i'm thinking about a winter setup for next year.
However my Jeep runs the EXACT wheel and tire sizes as my X5M and i got a set of 20x9 reps with 275 Square snow tires. I went this route so i can rotate the wheels/tires to get the most life out of them.
If down the road i decide to do something like this with my X5M i'll likely go the same route as there's an advantage in the snow to having a narrower tire. So i see no reason to pay extra money for wider rears when there's no advantage to it other than looks.
2010 X5M...Stock
2009 GTR...1100whp
2007 911 Turbo....Bolt on's.
2015 S4....EPL Stage 2
      11-30-2014, 10:32 PM   #5
dkreidel
dkreidel's Avatar
Drives: a lot of BMW's
I have square 255x19 snow tires without spacers on the X5M and X5 35i; works great in the snow.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option
      12-01-2014, 12:44 AM   #6
X5MFan
Drives: X5M 2012
If you move your rear wheels out 10 mm I would not call this plowing if not tracking perfectly. You plow more when you make a slight turn. Get a good winter set-up, square or stagger to your own preference and practice your winter driving. That is what I believe will make the real difference.
      12-01-2014, 09:11 AM   #7
troymi
Drives: '15 M235i Convertible
I've posted a similar thread on this. I have used 255/55/18 square setup without spacers, a 255/50/19 setup with spacers, and now a 275/40/20 front and 315/35/20 rear setup with Pirelli Ice/Snow.
By far the best performing in my opinion is the 20" staggered setup. We have driven in over 12" of unplowed snow, heavy slush, and also slick bare roads.
Any set of winters is going to be superior to summer or all seasons. It really comes down to what you want it to look like and how concerned you are with bad roads/potholes for tire damage and the availability of a replacement tire.
      12-04-2014, 11:14 PM   #8
particulardude
particulardude's Avatar
Drives: LR4 | L405 SC SWB
Any X5 w/ the fender flares looks hideous w/ a square setup.
That said, BMW should be ashamed of themselves selling MSports and Ms w/ summer tires anywhere that sees snow. They should come w/ all seasons unless you're buying in Miami, Phoenix or LA.
/thread
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude
      12-16-2014, 06:58 PM   #9
wowdao
Drives: 2007 BMW X5 4.8i
I have all the same tires for my snow setup with spacers on all four to widen my stance a lil, since I had wider wheels front and rear stagger. I have not experience any issue so far with my set up. I wouldn't see an issue with having stagger snow tires either. I would think you would have more traction. I just didn'e want to spend the money on 20inch stagger tires haha.
      12-17-2014, 09:32 AM   #10
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
a lot depends on where you test it .. unpacked snow, in a blizzard on the highway, Ice... If you wanna be safe do what they're telling you, go non-staggered all around, hell yeah it looks ugly, you're not being shot for magazine cover
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      12-17-2014, 09:38 AM   #11
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
If you want the best possible winter setup, a square narrow setup will in theory be the best thing you can do. The question is just how much difference will there be in overall traction/performance with a staggered vs square setup. If you have a staggered winter setup, you will be much better off than any other all season setup out there.
The other question is what are the actual conditions you drive in. Out of the 120-150 winter tire days, how many do you actually experience snow/snowpack/slush covered streets. In the midwest, I will say maybe 20-25 on average. To me that leaves a whole lot of days where you will just be on cold or wet conditions. For me I have 19" square set but that was because I found a great deal on a set of 211 takoff back in 2007. On my M3, I have a staggered setup which may not be the 100% best but I would rather have the staggered setup for the 80% of the time it is just cold vs the 20% of the time I have snow and slush conditions.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      12-17-2014, 10:10 AM   #12
///Mpower///
Sergeant
Drives: Spiritedly
Agreed. I went 19" non-staggered. Ugly, but likely most effective.
_______________
///M
      12-17-2014, 11:09 AM   #13
///Mpower///
Sergeant
Drives: Spiritedly
Exclamation
Question: What size spacers are you using on the front? ...and the rear? ...and which ones, ECS?, H&R?
Sorry for the inquisition...I'm thinking about using spacers and I'm a newbie to the concept, so I'm in info gathering mode.
Thanks in advance
_______________
///M
      12-17-2014, 01:47 PM   #14
X5MFan
Drives: X5M 2012
While the spacers make the winter tires fill out and the look is good, it really contributes to road spray on the side of the car. Winter driving usually involves driving on wet roads, including a salt slurry in the areas that use salt to help clear the roads. This is my second winter season with the 298 style 19 inch wheels and depending on how I feel next year I may take the spacers off when I put the winter tires back on. We will see.
      12-17-2014, 06:53 PM   #15
MRV99
MRV99's Avatar
I was going to put on spacers but like you mentioned. More protection for the paint by having the wheels a bit in.
--RIP--
      12-17-2014, 11:39 PM   #16
mrmomo313
mrmomo313's Avatar
Drives: M6 Gran Coupe
I refused to make my car look ugly in the winter so I opted with the Pirelli Scorpion Ice and Snow tires in OEM size. I run them on my stock 299m wheels and this setup has been beast for the last 3 winters. An M tuned X-drive + 640hp + performance snows = confidence inspiring fun even with snow on the ground
If your fenders and arches etc aren't protected I could see how running an aggressive setup could knick the paint because of the notorious E70 m/msport chipping issues. Otherwise I haven't had a single issue with my setup and would recommend it to anyone wanting to keep an oem look in the winter
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension
2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown
DME Stage 3
      12-18-2014, 12:36 AM   #17
exotich1
Drives: 2011 Monte Carlo Blue X5M
2011 BMW X5M  [10.00]
Hi,
This will be my first winter with the M, and after talking to local JEEP SRT-8 guys here I decided to go with these A/S tires for the winter, per their recommendation:
Front -
Delinte D8 Desert Storm 275/40R20
Rear -
DELINTE D8 A/S 4PLY BW - P315/35R20
Since we don't get much snow in MD, I am hoping the staggered setup with these A/S tires will help me get through the winter months.
      12-18-2014, 10:32 AM   #18
wowdao
Thanks in advance
I went with 15mm spacers all around. Found them on ebay with 40mm extended lug bolts. I also did a conversion on the spacer. center bore of 74.1 to 72.6. Needed to fit old 2002-2004 x5 wheels.
      12-18-2014, 10:52 AM   #19
///Mpower///
Sergeant
Drives: Spiritedly
Thanks for the info.
So I pulled the trigger on 20mm spacers for the rear. The fronts seem ok as is. I still may put 10 or 12mm spacers on the front once I see the final product.
_______________
///M
      12-18-2014, 09:36 PM   #20
mrmomo313
mrmomo313's Avatar
Originally Posted by exotich View Post
Hi,
Front -
Rear -
Have you considered the negatives of running an A/S year round. Or is that a trade-off you are willing to accept in order to run one tire?
DME Stage 3
      12-18-2014, 11:03 PM   #21
exotich1
Hi, no I am just running these for the winter season. My Bridgestone Run Flats are brand new. And as soon as spring hits, I will put them back on.
      12-18-2014, 11:39 PM   #22
mrmomo313
mrmomo313's Avatar
Good stuff!! Dedicated setups are the way to go
oh btw your fx is pretty sweet man, just saw the thread. looking forward to what you'll do with the new beast!
DME Stage 3
