12-04-2011, 05:49 PM | #1 |
Bebeqq1231
Rep 44
radiator leak on my 2008 X5 3.0 please help
This morning my coolant light came on and i add coolant to the top of the reserve tank, i drive the car for about 30 minute then the car srart to shake for 1 second and i see white steam under the hood then i stop immedity, I think is becuase i over fill the reserve tank, but not 100% sure. Then notice that there's dripping on the diverside lower coner of the radiator. I think is okay to drive the car home beacuse it's only 5 minute away, then i start car, no more steam or smoke and the car start and runs perfectly, no sign of engine light or coolant light. Will i damage my engine by drive it home (5 minutes away) Does any one know how much does the radiator cost? Can i intsall it myself? does anyone has the procedure how to remove and install it? Is this a common problem with the E70? Also i search on line there's a thing call K-seal that can fix the leak, Did anyone try that before? Thanks for your help
12-06-2011, 07:50 AM | #2 |
Rep 31
Yes, it's a common problem. I just had my radiator replaced because it was cracked. The plastic radiator is around $500 alone not including labor.
Also, do not put anything in the reservoir except BMW blue. |
01-29-2012, 12:54 PM | #4 |
Rep 2
Hi Can I ask you questions?
HI BeBeqq1231!
Same here. I have same situation here. Collant is leaking and dealer quote $1,500 for repair. I thinking replacing it myself. Can you please give me a part numbers to replace radiator? do we need to replace all the hoses together? Does it come with a installation instruction? Thank you. Last edited by kikim108; 01-29-2012 at 12:55 PM.. Reason: correction |
06-11-2013, 06:12 PM | #5 | |
DHS
213
Rep 4,026
Drives: 2023 M4, 2020 Land Rover
Any tips?
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
