      10-30-2017, 08:19 PM   #1
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
Heat issue
It is currently really cold in Chicago. So I turned on the heat and the car is only pushing heat through the passenger side and cold air out of the driver side.
I know it could either be a leaky evap system or low on freon. My question is, will the car give me a code for a leaky evap (my dads mercedes gave a code for a leaky evap)
I have a appointment to have it checked, but wanted to get some idea of what I am looking at having to get done.
      10-31-2017, 08:54 AM   #2
2slick4u
Corporate Thug
2slick4u's Avatar
Drives: 2009 X5 30i
Had the exact same issue on my e70. Thought a blower or even the heater core went bad. It turned out the electric water pump was the culprit. So I had it replaced along with the thermostate since it's located in the same area.
      10-31-2017, 08:35 PM   #3
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
had that done. Removed the lid to the coolant tank and it looks like I am low on coolant. Ordered some BMW coolant and will fill up and bleed tomorrow.
      10-31-2017, 08:41 PM   #4
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
No codes are stored for an evap leak..
      11-04-2017, 10:10 PM   #5
P1
P1's Avatar
11574
Drives: 2004 3/4 ton Duramax
Look through some of the paperwork that I gave you. I think some work was done on the A/C under warranty.
      11-05-2017, 06:43 PM   #6
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
I will send you a email. I don't recall the paperwork
