      09-12-2017, 02:34 PM   #1
coolmayank
Drives: X5m
X5m whats this component
Does any know what is this component called , it's on top of the turbo heat shield and seems to be connected to air intake hoses
Highlighted in red circle in the pic
      09-12-2017, 03:10 PM   #2
philly42
Drives: X5M, Z3M
It's part of the crankcase ventilation system. It's connected to the intake hose to pull vacuum for crankcase gasses. The part circled has a valve.
Is yours leaking oil?
      09-12-2017, 03:46 PM   #3
coolmayank
Drives: X5m
I see a small oil residue on this rubber hose, the temp of that area really grows high due to turbos
      09-12-2017, 04:30 PM   #4
philly42
Drives: X5M, Z3M
If possible check to see if you have oil passing through to the intake. There could be some oil passing through the valve into the intake system.
      09-12-2017, 07:45 PM   #5
coolmayank
Drives: X5m
How to check this philly42
      09-13-2017, 10:59 PM   #6
philly42
Drives: X5M, Z3M
You can use a paper towel and wipe the bottom of the intake pipe that goes into the inlet of the turbos. It's normal to find a little film of oil. Though if you find drippings of oil then most likely it's been traveling through your system.
