      08-17-2017, 12:26 PM   #1
E70_48i
Drives: E70 4.8i
H&R 1.2" Springs with Adaptive Drive
Would love opinions of those running the H&R 1.2" lowering spring kit with Adaptive Drive. I'm worried it will mess with the adaptive shocks and ride quality will be harsh. Who here runs this setup and what are your thoughts? Thanks!
      08-19-2017, 02:10 AM   #2
Leonelm3-X5M
M-Power Dallas !!!!
Drives: 01 Custom HPF 900whp Turbo M3
2010 BMW X5M  [10.00]
2012 BMW X5d  [10.00]
2001 BMW M3  [10.00]
Your fears or assumptions may be correct!
I am running the H&R 1.2 lowering spring kit w/adaptive drive and the ride is ridiculously Harsh!
i read somewhere else recently that i could loosen a bolt and re-position some bar in the rear suspension but im not home with the truck to try it
but im considering a KWV3 coilover kit and call it done
Leonel aka Rico /// BMWCCA # 403748
10 X5M - Pure Stg.2 turbos/K&N/JB4/Becker 3" Catless DPs/Megan Racing Ti Exhaust/H&R/Rohana RC22s/Vrederstein Ultrac Sessanta/Soon/+BMS+KWV3s+OSSDesign headlights.....
      08-19-2017, 08:25 AM   #3
socale39
Drives: 04 545i SMG
So you'd give up AD for a coilover setup? Giving up a lot for ride height...
      08-20-2017, 04:48 PM   #4
pers785
Drives: 2013 X5M
This makes me incredibly worried as I was planning to run H&R 2".....boo.
      08-20-2017, 06:38 PM   #5
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
Identical thread on another forym, FYI:
https://xoutpost.com/bmw-sav-forums/...ive-drive.html
Been running 1.2" H&R springs on my 4.8 with AD for 7+ years.
Ride is great (I don't have RFs but do run 22" Wheels in the summer), looks awesome too...
Go for it!
John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan
1995 Dodge Stealth TwinTurbo
Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      08-21-2017, 08:30 AM   #6
deansbimmer
Mporium BMW
deansbimmer's Avatar
3751
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
I'm running the 1.2 drop and rolling on 22's (w/ adaptive drive). The ride is definitely more harsh than stock suspension with cushy 20" tires. Now it's more akin to the ride in our E93 M3. At first the ride was far worse with the rear links adjusted to the length that H&R suggested in their instructions. I adjusted them to match the front drop after things settled and it is *much* better now. Perfect compromise between drop and comfort IMO.
This is my daily driver, and my wife doesn't mind the ride at all. She keeps trying to steal the X5M for herself and leave her M3 at home.
The 2" drop would be too harsh. Same for coilovers. Anytime you drop a car to that low you limit the suspension travel. All the X5 weight has to go somewhere when you hit dips and bumps. If you set the dampers to absorb everything you'll get a stiff ride. If you don't, thinking you'll be getting a cushy ride, then you'll be hitting the bumpstops all the time and constantly bottoming out the suspension which is bad for component longevity (and potentially unsafe). Bottom line is lowering of any kind will sacrifice ride quality. The more you lower the more comfort will be lost.
      08-31-2017, 04:38 PM   #7
RDR142
Drives: 13 X5M, 13 PANI GTS, 10 LRSC
Just installed 1.2 H&R fronts with rear links set at 67mm. Love it. No harsh ride, no bouncing whatsoever. Less body roll cornering. Feels a little stiffer than stock but certainly worth it for the look.
Must mention that it's on stock 20's with non-runflat. The increased stiffness almost feels like the car felt with runflats.
      08-31-2017, 06:02 PM   #8
pers785
Drives: 2013 X5M
Were you ever considering the 2.0" drop? Are you happy with how low it is?
      09-01-2017, 06:38 AM   #9
RDR142
Never considered 2.0. i'm more than happy with how it sits now. corners level and bumps aren't harsh at all.
i'd post a pic if i could figure out how to on iphone
