      04-16-2016, 08:21 PM   #1
globalx5m
Drives: 2012 bmw x5m red
x5m black smoke out right exhaust
hello every one have 2012 bmw x5m 86k miles just replace new injectors about 2k miles ago under recall after that i see black smoke out right side exhaust and black little spots all over rear bumper and tail gate it oil . truck all stock no check engine light . any body have this issue . thanks in advance
      04-21-2016, 03:08 PM   #2
peloterogq
Drives: bmw x5 50i
injector are leaking double check any fuel smell from the exhaust. check in the morning went the car is cool
      05-03-2016, 08:36 PM   #3
globalx5m
just pick up x5m from dealer , they found # 4 leaky injector, problem is solve
      09-19-2017, 06:39 PM   #4
need4doors
Drives: 2010 x5m
Will the injectors leak to the point of wiping the oil off the cylinders or does reduced power stop the vehicle before this happens?
      09-24-2017, 10:02 AM   #5
philly42
Drives: X5M, Z3M
Does anybody know this fuel injector leaking issue in depth? What's puzzling is that fuel injectors are replaced with updated versions yet they continue to leak.
My injectors were replaced last year and a few days ago I had some bad idling though no CEL. I checked for fault codes and found one for a misfire. In testing the system it was noted that fuel injector 1 should be replaced.
So after so many versions of fuel injectors, they still continue to fail??
The point I'm trying to raise is could the problem really be with another component and changing the fuel injectors is just a temporary fix?
