      01-07-2010, 12:02 PM   #1
Sammydtd
Sammydtd's Avatar
Drives: X6 50
Which is more comfortable over bumpy roads & potholes, 50i( 21" 215s) or X6M (20")
Our roads are very crappy and full of potholes, speed bumps and other nuisances. I have the 21" 215s in Ferric and they make my 50 very bumpy. Would the X6M with the standard M 20" wheels offer a worse or more comfortable ride?
Thanks
      01-07-2010, 02:28 PM   #2
Allex18
Allex18's Avatar
Romania
23
Drives: E90 318I 2007 full
X6 35d whit "20 sport suspension very bumpy on bad road , but on a good mountain road it rulz
07 E90 318i black on black
10 E71 X6 xdrive35d black on black
      01-07-2010, 03:03 PM   #3
Skywagon
Skywagon's Avatar
15
Drives: X6 3.5
Try some 20's without run flat's if in fact you are running them. 19's may even be better, more tire side wall helps cushion the ride.
      01-07-2010, 03:44 PM   #4
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
+1
RF's give harder ride but then again if all you have are these kind of roads you may need the RF's.
      01-07-2010, 05:32 PM   #5
Sammydtd
Sammydtd's Avatar
Drives: X6 50
But what about my question, would the 20" rims on the M X6 be a smoother ride than my current 50i with 21" wheels??
      01-07-2010, 07:18 PM   #6
Andrew 912
//M addicted
Drives: AW M3 E92 - MR X6M
X6M very smooth ride and not bumpy at all
      01-10-2010, 02:35 AM   #7
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
Thanks
The tire with more sidewall height will ride better on rough roads.
The tire diameter is virtually the same regardless of the wheel size - the just lower the sidewall profile of the tire as the wheel get's larger. The shorter profile with a large wheel has less "flex" and rides rougher on bad roads.
If you want a better ride change to a smaller wheel and a tire with a taller sidewall.
      01-10-2010, 12:39 PM   #8
Sammydtd
Sammydtd's Avatar
Drives: X6 50
Exactly the advice I was looking for, so they're both pretty much the same feel!
      01-10-2010, 12:50 PM   #9
teagueAMX
teagueAMX's Avatar
The 20's will have a slight better ride quality on a bumpy road then the 21s
      01-10-2010, 08:50 PM   #10
ZKA
ZKA's Avatar
Drives: 2010 BMW X6 M
Try deflating a little air from all the tiers, maybe 2 PSI since u might be on runflats. Might not be as responsive, but the ride should be a little smoother.
2010 BMW X6 heavy, but yu///Mmy
2002 BMW e46 ///Mic jerky 3 - Sold
1995 BMW e36 ///Mic chassis flex 3 - Sold
