      07-27-2018, 11:23 AM   #1
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
Changing X6M E71 stock exhaust tip to carbon fiber
Hi all,
Just want to know if anyone knows what the diameter of the stock pipe size is so i can order the proper size inlet. Thanks.
      07-27-2018, 05:05 PM   #2
jschill31@gmail.com
jschill31@gmail.com's Avatar
Drives: 2014 X6M
Originally Posted by do_0b View Post
Hi all,
I am also interested in doing this... My chrome ones were filthy but I found a quick and easy way to clean them. Don't laugh but use Coke and tinfoil. You will be shocked with how much of the carbine comes off.
Please reply if you figure out a good carbine tip option!
Cheers
X6M
      07-28-2018, 10:09 AM   #3
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
The inlet starts out at 65mm (Inside diameter (ID))...starts tapering to 55mm (ID) after 25mm in depth...so looking at Akrapovich type knock-offs is quite the challenge...if you come up with a solution...that either goes over the chrome tips...or replaces them...I'm in....
      08-09-2018, 09:59 AM   #4
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
i read somewhere that the OEM tips can be pulled off. I ordered the 63mm inlet tips from eBay..will install once i get them and report back.
      08-09-2018, 12:25 PM   #5
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Awesome. Please post pics when you get them.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
      10-07-2018, 03:48 PM   #6
nikita_567
Drives: BMW X6
Yes please do, I want to see it as well
      11-13-2018, 11:48 AM   #7
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
turns out the outlet (4.5") is too big wont fit. now im stuck with 4 of these carbon tips lol. to make the clearance i can go only max 3.5" outlet ugh!
      11-13-2018, 11:53 AM   #8
0-60Motorsports
Bahrain
792
Can you post a pic with measurements and what needs to be what size please
Current Mods:
IG: @060Motorsports
      04-03-2020, 08:25 PM   #9
Bilbofraggins
Did you ever complete this project....?
With time on my hands...and the weather getting nicer...I'm about to give removal of existing OEM tips ago...
Then take it from there...
      04-04-2020, 08:50 PM   #10
argento
argento's Avatar
538
Drives: 2013 X5M
Interested to know if tips can be pulled off. On the x5m there is a punched dimple fixing each tip to the exhaust pipe...or at least so it seems. You should be able to drill it out and then remove?
