      12-23-2015, 01:20 PM   #1
Nicky P
Drives: M3 Saloon
Non BMW Branded Wheels
Can anyone advise if it's safe to fit non BMW brand alloy wheels 20/21" to a new F16 knowing the off set might be very slightly out by (5mm). And would this have an effect on the warranty?
Thanks
NP
      12-25-2015, 09:41 AM   #2
empwrd
Drives: 2012 Bmw X5m
just worry about tire sizes.. Either go with a square setup or the recommended tire sizes like 285 35 21 AND 325 30 21
      12-25-2015, 07:46 PM   #3
mmelany
Drives: 2011 X6 35i with Sports Packag
Empwrd is right. Tire size is really what matters..if you are considering 20's, go 285 40 20 and 315 35 20. EOM
      12-25-2015, 09:51 PM   #4
empwrd
275 315 for 20s... 285 325 for 21... 295 335 for 22.... These cars have finicky sensors in them that measure wheel speed independently from each other.. As a result, smaller diameter tires front to rear will cause massive problems with the transmission. Ie It shreds to shite...
      12-25-2015, 09:55 PM   #5
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Width front to rear is irrelevant, the most important thing is the same rolling diameter all around...the sizes empwrd just mentioned.
