      05-19-2013, 12:10 AM   #1
Lerpal
Drives: x6 3.5
Is any bigger break solution for x6 (excluding Brembo)
Hope most of you will agree that adding Brembo set (over $8K) to lease car is not the most practically solution especially if your major objective is to achieve better look. After some research on this forum I found that bigger break from x5M can be fitted on x5, but seems that no one confirmed that x6M break can be fitted to x6 (3.5/5.0). Does anyone was able to make this trick?
Also if any other option exists for bigger, better looking break for x6 (3.5/5.0) please share your knowledge. Thanks.
      05-21-2013, 05:55 PM   #2
Lerpal
Drives: x6 3.5
Can't believe that I am the only one who want to fit big nice looking break to x6(3.5) without spending $8K on Brembo set... I am sure someone was able to do that trick for less money.
Help.... help... help
      05-21-2013, 07:04 PM   #3
Biff Grissel
stankmouth
Biff Grissel's Avatar
Drives: fun
Stoptech is cheaper.
      05-23-2013, 09:33 PM   #4
Lerpal
Drives: x6 3.5
Well… seems like stop tech will run around 5.5K … still a lot
Start looking into x6M set but seems like rear brake smaller them front… is that right?
      05-24-2013, 10:40 AM   #5
dkreidel
dkreidel's Avatar
Drives: a lot of BMW's
Correct
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option
      05-24-2013, 10:49 AM   #6
P1
P1's Avatar
11569
Drives: 2004 3/4 ton Duramax
You are installing $5K-$8K brakes primarily for looks? I would spend that money on some wheels that CONCEAL the brakes instead.
      05-26-2013, 12:46 AM   #7
Lerpal
Drives: x6 3.5
That is exactly what I don't want to do: spend $5K-$8K just to have better looking car.
Why for 3-series you can buy great looking M Performance brake for $2K+ but when comes to x6 brake upgrade it's so expensive.
I was hoping to find some cheaper solution but the only one I see so far is to paint my original brake in red (I have white car).
Would be nice to see pics if some one did so.
      06-03-2013, 07:59 PM   #8
Boosteeddc
Drives: 2010 x6m
Get with a x6m owner whose looking to upgrade to aftermarket breaks and buy theirs while they buy new ones?
