12-28-2023, 02:30 PM | #2 |
Rep 139
What kind of Seats are present now in your car, and witch version you wanna build in.
(If you don’t have heated Seats, and you get heated Seats you Will need another airco controller) als check of your connectors are filled with wires. Adapting plugs is the lesser problem, if you should buy a seat, ask if the body connector with some wire could be with it. It looks like that all of the buttons for the Seat are on the seat. I guess that a sport seat has a different coding than a comfort seat. On WDS you could find out the wiring and connectors, of a good Google search. |
12-28-2023, 04:23 PM | #4 |
Rep 139
I did a look around in realoem, i see there that is looks like they changed seat computer.
So that good give Some problems. So i am almost shure that you will need The body conrectors, and it Will be a puzzle. I have no idee if the CAN high and low are the same (thats for memory and heating) |
StradaRedlands4940.50 |
