      03-15-2023, 12:37 PM   #1
bomhour
Drives: 2010 BMW X35d
SCR Module
Hi all, I've been searching hi and low for a DIY or image or microfiche of the location and removal of the SCR module. I have a 2010 BMW X35d. If you know where this module is located it would be very much appreciated.
      03-15-2023, 09:08 PM   #2
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
The SCR Delivery module on the active tank? If so here it is
      03-15-2023, 09:47 PM   #3
bomhour
directly atop the the DPF tank. Looks like I'm removing the wheel well plastic after the wheel is off. thanks for the heads up!
      03-15-2023, 09:49 PM   #4
bomhour
where did you get the image from?
      03-15-2023, 10:08 PM   #5
jbash87
2006 BMW M5  [10.00]
newtis.info but I've heard it's shut off for anyone who didn't get a chance to sign up for it years ago.
All the info on that site can also be found in the ISTA software.
      03-16-2023, 02:06 PM   #6
bomhour
Ok, thanks for the tip!
      03-16-2023, 03:49 PM   #7
jbash87
2006 BMW M5  [10.00]
That part number was never installed on an E70. Are you sure that's the right part?
      03-16-2023, 03:53 PM   #8
bomhour
You are correct, the SCR Module came about in the next generation X5. that clears it up, just going in the passenger wheel well to get at the delivery module.
thanks,
Tags
e70, scr, x35d
