      04-17-2014, 02:17 PM   #1
rockriver15
Drives: 2008 328i coupe
Rearview camera question
Hey guys I have a question about a rear view camera.
I have a 2011 x5 that is having a flickering issue periodically with the rear view camera. The dealer says it needs to be replaced.
I pulled the rear panel and it is very easy to get to the camera and they are fairly easy to come by. The question is would it be a direct replacement or is there coding that's needed? Of course the dealer wants $800 for the job and the camera is around $300.
Any help is appreciated!
      04-17-2014, 05:18 PM   #2
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
Is your 2011 a early 2010 build date? Otherwise it would be covered under warranty. my 2012 was built in late march 2011so that is the only reason why I ask.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      04-17-2014, 05:19 PM   #3
X5ist
X5ist's Avatar
11
Drives: X5
just replace it yourself and get it coded if it needs one...but I dont think you need to get it coded
2007 X5 4.8i Sports, Adaptive Drive, Rear Entertainment -In 2013 Nissan Juke Nismo AWD -In
2011 Mini Cooper S Countryman All4 -Out 2007 MB ML63 AMG- Out 2007 Acura MDX SH AWD Elite Package - Out 2008 Infiniti EX35 Journey iAWD - Out 2003 Nissan Murano SE AWD - Out2003 Infiniti FX35 AWD Tech Package- Out 2001 Subaru WRX - Out 1999 Subaru Forester S - Out 2003 Toyota Matrix XR AWD - Out
      04-17-2014, 05:34 PM   #4
rockriver15
Yea, sorry should have included that. Early 2010 build. I figured that would be the best route to go was do it myself. I guess the bigger question can it be coded by someone other than the dealer, like a vendor from one of these sites? Or os there more advanced things that had to be done by a tech.
      04-17-2014, 08:37 PM   #5
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
My guess is that the output of the camera is probably one of the industry standards (you'd want to match the resoultion), but the field of view for the camera would also need to be the same for an aftermarket unit to work properly. You may also find the low-light visibility may be different, giving you an unusable image at night on some.
      04-17-2014, 08:56 PM   #6
rockriver15
I found an oem camera that seems readily available online. I would go that route rather than trying to retrofit an aftermarket camera assuming the camera is the problem here.
      04-17-2014, 10:36 PM   #7
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
I also have a 2011 and it started doing it a few days ago. Not in the morning but in the afternoon if the weather is hot. Off to the dealership when i get some time.
      04-18-2014, 10:15 AM   #8
joe_planet
Drives: 2011 X5d
If you replace it with another BMW OEM camera you shouldnt need any coding.
      04-20-2014, 12:09 AM   #9
rockriver15
Maybe I'll give it a shot.....Larry if you end up getting. Fix could you post the outcome?
      04-20-2014, 12:22 PM   #10
larryv
larryv's Avatar
64
It has been cooler this week and no problems. I have searched and others have had problems when the weather has been hot. Hot or cold i should not have any problems. I will post when i get to the dealership. Thanks
      04-24-2014, 12:16 PM   #11
crm102b
crm102b's Avatar
Drives: X5M/F95, M5/F90
Re: Rearview camera question...
Per attached, this back-up camera system is seriously complicated. Along with the three cameras, there are several other active and passive components to go wrong.
For instance, the display is dynamically affected by both speed- and turning radius. And there's an automatic defroster that thaws the lens whenever the ambient temperature dips below 32°F. The system also accesses the vehicle's ride-height sensor. And it knows when a trailer is attached — which enables a zoom function. It goes on...
After about a year, the system on my 2010 X5M had become more-or-less unusable due to flicker. The dealer replaced all three cameras to no avail. Eventually the problem turned out to be a faulty wiring harness.
Attachment.
      04-24-2014, 05:15 PM   #12
rockriver15
Thanks for posting that. Were you experiencing flicker in all three cameras or only in the rearview camera?
      08-25-2014, 04:26 AM   #13
KeithOwen
Germany
Drives: BMW X5M (2010)
Hi All,
I too am having issues with the rear view camera on my 2010 X5M. As others on the board have experienced, it flickers and becomes unusable. It is much worse in hot weather, so much so that around 28 degrees Celsius it simply goes black. The side cameras seem fine, as does the PDC, it's just the camera in the tailgate.
So far the camera has been replaced (under warranty) but that didn't fix it. From what CRM102B said, it seems that the cabling is the likely culprit. Has anyone else had this issue, and can let me know exactly what was replaced to fix it, so I can let my dealer know. Thanks!
      08-25-2014, 09:00 PM   #14
larryv
larryv's Avatar
64
KeithOwen, my 2011 goes into the dealership tomorrow for the same problem. I will give an update when all is working along with all that was done with part numbers.
      08-26-2014, 09:41 AM   #15
smyles
Drives: '21 X5
Originally Posted by KeithOwen View Post
Hi All,
Yes, you'll need to replace the HSD cable (~$220) that goes from the camera to control unit under the steering wheel. It's a possible DIY, but involves a lot of trim work.
      08-26-2014, 10:55 AM   #16
iDido
Drives: 2012 BMW X5
@ smyles
That's were the camera control unit is located. Thanks, I was looking for this smyles
Did you do an OEM camera retrofit or you just had to replace your HSD cable?
      08-26-2014, 12:51 PM   #17
KeithOwen
Germany
Thanks for the info!
      08-26-2014, 01:05 PM   #18
smyles
Drives: '21 X5
Originally Posted by iDido View Post
@ smyles
My camera was acting up similar to KeithOwen's, so first I pointlessly replaced it (hence one for sale in classifieds), then procured the cable and - after the sticker shock weared off, - replaced it.
      08-26-2014, 04:45 PM   #19
iDido
Drives: 2012 BMW X5
@ smyles
Thank you,
I asked because I'm in the middle of doing a retrofit on my X5.
      08-30-2014, 04:26 AM   #20
KeithOwen
Germany
I'm still waiting for the dealer to get the cable in. Hopefully will be done next week
      09-03-2014, 04:59 AM   #21
KeithOwen
Germany
Cable is here and being replaced today
      09-05-2014, 09:01 AM   #22
KeithOwen
Germany
Cable is replaced and all is good so far. Mind you the weather's not been so hot recently so it's hard to tell
Hopefully it's all fixed now
