      11-25-2015, 08:19 AM   #1
09x5xdrive48i
09x5xdrive48i's Avatar
Drives: X5 4.8i
Adding Satellite Radio when to existing Satellite Preparation
What is the most cost efficient option to add satellite radio if your car already has dealer installed 693 - Satellite Radio Preparation?
Can this be done by yourself without taking to the dealer?
Thanks in advance
      11-25-2015, 08:57 AM   #2
smass
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Instructions attached. In theory, you can simply purchase a tuner on ebay, plug it in and code (which I think you already did). Just do some homework to make sure the connectors are where you expect them to be. And figure out what bracket, if any, is needed.
File Type: pdf Sirius installation instructions [e70 X5].pdf (391.0 KB, 240 views)
      11-25-2015, 09:03 AM   #3
09x5xdrive48i
Drives: X5 4.8i
Ahhh... Lovely... Thank you kindly good sir!
PS. How nice when someone that knows the answer, points you in the right direction without unnecessary complications...
09 X5 xDrive 4.8i - Sapphire Black/Saddle Brown
Sport, Premium, Sound, Tech, Cold Weather, Comfort, Adaptive
      11-25-2015, 09:20 AM   #4
09x5xdrive48i
Drives: X5 4.8i
smassey,
so the tuner can be any tuner, ie search for: "universal satellite tuner" on ebay?
or are we taling about a dedicated BMW tuner, such as this one: http://www.ebay.com/itm/07-13-BMW-X5...xWMqT7&vxp=mtr
      11-25-2015, 12:04 PM   #5
smass
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Originally Posted by 09x5xdrive48i View Post
smassey,
It needs to be the dedicated BMW tuner which hooks to the idrive with fiber optic connectors. A generic tuner will not do that.
      11-25-2015, 12:54 PM   #6
09x5xdrive48i
Drives: X5 4.8i
Gotcha. So final question: will any BMW tuner work? Or does it have to be one specific for E70?
      11-30-2015, 09:43 AM   #7
smass
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Check realoem to get the part number for your e70 (lookup by vin). Then look for that part number which probably was used on multiple BMW models.
      12-01-2015, 11:19 AM   #8
sergeny1
sergeny1's Avatar
14
Drives: 2021 X4C
You will also need to connect fiber connector in the hub
