PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
E90 335d Square Wheel Setup Recommendations
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
08-16-2017, 05:01 PM | #1 |
Rep 1,157
I wanted to get some input from the pros about a square setup on my car.
The Car: E90(2010) 335d on Koni Yellows and OEM Sport springs. Currently staggered with 225/40-18 up front and 255/35-18 in the rear What I'm Wanting: A tire width no less than 245, and a wheel diameter no more than 18 inches(17 inches preferred if possible). I like a "meatier" look. 255 on an 8.5" wheel is okay. 245 on a 8" wheel looks really good to me. Aspect ratio can be adjusted to be close to the current overall diameter. What I Don't Want: I don't want to do any crazy camber adjustments, and don't want to roll/pull fenders. I'd like to avoid having to use spacers if possible. I don't want the wheels to look sunken in. I'd rather they stick out a bit. I've been looking at Apex Arc-8s heavily. 17x8.5 ET20 with 255 tires sounds nice, but I have no idea how that will fit on my car. 17x8.5 ET40 with a 10mm spacers and 255 tires is also an idea I had, but again, I'd like to avoid spacers. I test fit some 17x8.5 ET40 wheels with 245 tires and it looked okay, but I'd like that extra width on the tire is possible. Pictures are appreciated. Wheel recommendations are great. Any ideas you may have, I'm all ears. |
08-17-2017, 03:41 AM | #2 |
Rep 321
I just recently went from square Style 159 17x8 ET34 PSS 225/45R17 to square Avant Garde M310 18x9 ET38 up front and ET23 (with 15mm spacer) at rear with PS4S 245/40R18. They fit the front perfectly clearning my Bilstein B8 on Eibach Pro springs by 1-2mm. No rubbing. The rears fit perfectly with no rubbing. I think 20mm spacers at rear would've been perfect, but I wanted to play it conservatively. I tried running 5-7mm spacers up front, but they would rub when taking aggressive corners with dips.
08-17-2017, 04:08 AM | #3 |
Sleepy
75
Rep 367
I just did 18x8.5 beyern spartans with ET30 and 245/40/18 conti pure contacts no spacers. Front rubs slightly in reverse with wheel cranked over but not forward. I also have a 2010 335d.
08-17-2017, 08:36 AM | #4 |
Rep 1,157
This is rubbing on the inside I'm guessing? Can you send pictures of how your car looks?
08-17-2017, 10:34 AM | #5 |
Guest
Rep n/a
Drives:
Going wider in front without adding at least a little bit of camber is almost pointless from a performance perspective.
It should look "better" though. You'll also be able to rotate tires front to rear, so at least you'll have that going for you. |
08-17-2017, 10:53 AM | #6 | |
Rep 1,157
My stock wheels are in bad shape so anything is an improvement. |
08-17-2017, 11:18 AM | #7 | |
Rep 1,157
08-17-2017, 08:52 PM | #8 |
BimmerPost Supporting Vendor
1437
Rep 2,650
I appreciate you thinking of us. The following square fitments would meet your criteria. Note the 17x8.5" ET20 you mentioned is an E30 M3 application and not one we typically stock (low demand).
17" Option 1 17x8.5" ET40 - 245/40-17 Option 2 17x9" ET30 - 245/40-17 18" Option 1 18x8.5" ET35/38 - 245/40-18 Option 2 18x9" ET30 - 245/40-18 255's can be used, especially on the 17x9" and 18x9" square fitments where the wheel width warrants the wider tire, however that is getting close to requiring just a touch of negative camber to ensure you do not rub. Many enthusiasts do it without dialing in negative camber, however tire brand and ride height variables may allow one car to be rub-free, while another slightly scrubs. Even if you need a touch of negative camber with the 255's, it is really easy to pull the factory camber pins and align the car. Adjustable camber plates are not required. Here are two different E90 sedans running the same ARC-8 17x9" ET30 square with 255/40-17 tires - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-17-2017 at 09:04 PM.. |
Torqu3320.50 |
08-19-2017, 03:35 AM | #9 |
Sleepy
75
Rep 367
That top pic looks damn good
ApexWheels1436.50 |
08-28-2017, 06:29 PM | #12 | |
Rep 1,070
I've got Apex EC-7 with 18x9 wrapped in 255/35/18 Michelin PSS. They look great and don't rub. I just ordered a new set of the same tires, but now I'm wondering if I should have gotten Michelin Pilot Sport 4S in 245/40/18.... they're supposed to be a bit quieter, more sticky in rain and allegedly more sticky at the limit. Just don't know if I want to give up 1/2 in width as the current set-up looks cool...
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
08-29-2017, 09:48 AM | #13 | |
Guest
Rep n/a
Drives:
If you're rolling around with stockish alignment settings, you wouldn't notice the difference in width either way. |
08-29-2017, 01:30 PM | #14 | ||
Rep 1,070
JWebb335xi
08-29-2017, 01:36 PM | #15 | ||
Rep 1,070
Going with the 245/40/18 PS4S. Very interested to see how they compare to the PSS in my car..
JWebb335xi
08-29-2017, 08:31 PM | #16 | ||
Rep 1,070
JWebb335xi
09-05-2023, 08:10 PM | #17 | |
Rep 8
03-13-2024, 01:22 AM | #19 |
Rep 1
Going wider in front without adding at least a little bit of camber is almost pointless from a performance perspective Traffic Jam 3D
03-13-2024, 10:36 AM | #20 |
scotthilly
79
Rep 114
I've got a 335i with the staggered 18's and am switching to a 17x9et30 with 245/40/17 square setup. Everything I've seen looks great and I'm looking forward to better ride quality and pothole resistance. I think e90 lci's still look ok with 17's!
