Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Members Classifieds : For Sale / Wanted / Group Buys
      12-06-2020, 03:46 PM   #1
Titaniu//M
Titaniu//M's Avatar
48
Drives: M3
FS: OEM BMW Performance Style 375 Double Spoke 21” Wheels F15 X5 – Northern Virginia
BIMMERPOST / Classifieds
Asking Price:
Sold
Item Interest
Up for sale is a set of 4 OEM BMW Performance Style 375 21” wheels. This is an official package offered by BMW for the F15 generation X5. Should fit the E70 X5 as well. Original BMW wheels – not replicas. Setup retails for over $5k from the BMW dealer.
Wheel Specs:
Front: Part number 36116796149. 21x10 ET40, 5x120 bolt pattern, 74.1 Center Bore
Rear: Part number 36116796150. 21x11.5 ET38, 5x120 bolt pattern, 74.1 Center Bore.
Tire Specs:
Pirelli P-Zero Run Flat tires –
Front: 285/35/R21 105Y XL
Rear: 325/30/R21 108Y XL
Wheels are in very good to excellent cosmetic condition. I would conservatively rate them an 8.5/10. There are a few small areas where it appears curb rash has been repaired by grinding, sanding, and polishing the damaged areas. These repaired areas are very difficult to see unless they are pointed out. Perhaps a few minor scratches/scuffs from normal use. No cracks or bends of any kind.
Tires are too worn to be considered of any appreciable value. Front tires have maybe one season left in them (4 to 5/32nds remaining), rears are at the wear bars and require immediate replacement.
TPMS sensors are mounted, but from 2015 and batteries have likely run out.
Includes Genuine BMW center caps.
Asking $OLD cash for the set of 4, picked up in Fairfax, VA. Will entertain reasonable offers.
Local pickup strongly preferred due to weight/size. As a last resort I will entertain having the tires dismounted and shipping the wheels only.
Next two images show the most noticeable of the repaired areas. You can see the light does not reflect off a small area the same way it does off the rest of the wheel.
2006 BMW E46 M3 Coupe - 6MT - Titanium/Imola
1999 BMW E36 M3 Coupe - 5MT - Estoril/Dove
2000 Honda Civic Si
2011 Toyota Tacoma PreRunner T/X TRD
