      11-29-2019, 11:55 AM   #1
Al3029
Drives: 2012 E93, Msport, white/red
08 E70 No Start/No Crank
Hoping to get a little help, my E70 3.0 has a no start, no crank. Everything turns on, lights, radio, etc. I replaced the battery with no luck. Prior to the no start situation, i had on several occasions when I went to start the vehicle it will hesitate to start and had to press the start button again until it started.
After doing a little research I see some folks had issues with the CAS relay, which solved the issue. Also, possible starter issue?
Order the relays, will arrive in a couple of days, hoping this solves the issue.
      12-06-2019, 07:11 AM   #2
Al3029
Fixed, it was the starter.
