      10-19-2014, 05:22 PM   #1
particulardude
particulardude's Avatar
Drives: LR4 | L405 SC SWB
Anyone else experience either of these small issues?
I'm curious to hear any feedback on these before I whine to my dealer... tia
-Whenever someone sits in the back seat on the driver's side there is a pretty tragic sounding creak noise - only when cornering. It's loud enough to think it's something with the suspension but it's definitely interior. At first I thought the bar that holds the hatch cover wasn't secured as I had it out a few days prior to the first time it happened. However, I pulled over and triple checked that and the issue repeated itself when that seat has been used again. It's rare I have anyone sitting there so it's not urgent but still bother's me thinking something is loose. Anyone else experience this?
-The second is a bit more serious as it could easily cause be to bump into someone - it's abrupt lurching at low speeds while in drive but w/o depressing the accelerator. I always let the truck warm up to the point of the idle dropping but I find the lurching to be inconsistent. Once it went to the point of stalling the truck which was really surprising. It is most common when I have the wheel cranked as far as it will go while parallel parking/leaving a spot. I want to say I read something about this issue being related to a recall but I can't find the thread again.
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude
      10-20-2014, 07:25 PM   #2
twozzie
Drives: X5 4.8i Xdrive
My 2009 was lurching during braking from 2nd to 1st gear, on the 3rd time into the dealers they decided to put a new transmission in . Car has 83k miles.No idea if its remotely the same issue but it was lurching.
      10-22-2014, 08:08 PM   #3
particulardude
Thanks twozzie.
Anyone else experience either of these issues?
      10-23-2014, 02:29 AM   #4
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
Had a similar issue, reset adaptions. Solved the problem.
Creaking issue try this
      10-23-2014, 10:03 AM   #5
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Mine is going in soon for the transmission issue...
      10-24-2014, 05:34 PM   #6
particulardude
Seriously? Was there any specific diagnosis from the dealer related to the lurching?
      10-24-2014, 05:39 PM   #7
P1
P1's Avatar
11572
I just told them it's "jerky" going from 1st to 2nd and they told me to bring it in. Nothing beyond that...
      10-24-2014, 07:13 PM   #8
particulardude
Hm. Well I feel like it's not that big of a deal but I'm worried about bumping someone coming out of a parallel spot.
      10-27-2014, 08:39 AM   #9
Alachua
Drives: E46 M3, E39 M5, F85 X5M
There definitely feels like a delay on our 2013 X5 regarding the throttle when in gear (from a stop, you feel like you're pushing the throttle and nothing happens for a split second, then wham! you're off quicker than you wanted to) - but it shifts smooth into other gears. But haven't experienced the creaking noise.
