      10-15-2014, 03:50 PM   #1
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Dont let bmw rape your engine
It was 6k miles when I decided to do an oil change just for the heck of it ... I was surprized to see the condition of oil ... diesels usually turn oil black quickly, but this one seemed to have lost viscosity pretty bad, there were particles (dust or ??) in the oil, the filter was a mess ... I'm planning on changing every 5k, inbetween bmw's oil change (10k) ..... I also used AMSOIL Engine & Trans Flush right before draining it ... I'm at 26k mileage ... I've seen lab reports showing oil good & what not, I think anything over 5k is just not right for the car
http://www.amsoil.com/shop/by-produc...code=FLSHCN-EA
Will upload pics to the filter and oil - If someone needs directions to perform DIY oil change on x5d M57 feel free to PM me
      10-17-2014, 02:39 AM   #2
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
welcome to the club. I have been around engines long enough to "disagree" with BMW's intervals... TT motors are even harder on the dino juice
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      10-17-2014, 08:11 AM   #3
P1
P1's Avatar
11568
Drives: 2004 3/4 ton Duramax
I assume you gents are looking to keep your X5s past the warranty expiration?
      10-17-2014, 01:00 PM   #4
MRV99
MRV99's Avatar
I just like taking care of my cars. Yes I spend a couple hundred bucks more but that's just the way I am
--RIP--
      10-18-2014, 08:36 AM   #5
PAX5
Drives: 2012 X5 50i
Originally Posted by 007_e350 View Post
It was 6k miles when I decided to do an oil change just for the heck of it ... I was surprized to see the condition of oil ... diesels usually turn oil black quickly, but this one seemed to have lost viscosity pretty bad, there were particles (dust or ??) in the oil, the filter was a mess ... I also used AMSOIL Engine & Trans Flush right before draining it ...
Engine flushing is a highly controversial subject.
... therefor I don't really want to bring it up for discussion ... but I just want to remind everyone that BMW categorically recommends AGAINST engine flushing of any kind. They believe that using one of their recommended high detergent oils oils such as Castrol is sufficient.
I believe that the reason behind this is that BMW cannot control the formulation of the engine flush products, but it's highly likely that the potent aromatic hydrocarbon solvents can and will strip the beneficial wear layer film on the metal surfaces that was put there by the detergents of a high quality oil.
These same potent solvents also wreak havoc with the paper and rubber components inside the oil filter ... that may have been the "particles and dust" you saw ...
Nothing wrong with 5K mi oil change intervals ... just don't flush your engine!
Caveat Emptor.
PAX5
BMWCCA 20645
      10-18-2014, 02:39 PM   #6
007_e350
007_e350's Avatar
Caveat Emptor.
You sound like my grandpa, modern engines dont need the film.of burnt oil to keep compression etc, tolerances are kept extremely tight ..rather if oil passages are blocked something will start suffering from lack of lubrication.... diesel engines in particular need flushing to clear up passages, also this product is sold by the dealer and they recommend it for diesels... your analogy however os better suited for gas engines, ill however be doing a one time flush in my other car just for experimentation purposes
      10-18-2014, 06:02 PM   #7
PAX5
Drives: 2012 X5 50i
... ill however be doing a one time flush in my other car just for experimentation purposes
Go for it!
PAX5
BMWCCA 20645
