      10-12-2014, 04:04 PM   #1
srbarnes4ever
Drives: 07 335i E90 Sport
Clunky transmission
Just clipped 60k miles in wifey's E70 and transmission now clunks in 2nd and 3rd gears during low speed conditions. Also seems like the shift from Park to Drive has a lag to it before drive is engaged. This sound like fluid or something more dire?
      10-13-2014, 07:10 AM   #2
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Fluid flush / refill should take care of that - do you tow a lot ?
      10-13-2014, 09:49 AM   #3
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
What year is the x5. 6at or 8at
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      10-13-2014, 11:40 AM   #4
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Interesting you bring this up. Mine is about to hit 50K (2011, 8AT) and I am experiencing jerky 1st and 2nd gears. Odd thing is that is only happens when it's in D. The second I shift gears using automanual, the issue is no longer present.
      10-13-2014, 03:46 PM   #5
srbarnes4ever
Never towed anything my friend. 60k miles of 2 kids chucking chit in the rear seat areas is the most abuse she has endured!
      10-13-2014, 03:47 PM   #6
srbarnes4ever
'11 X5 35i Premium with 8at
      10-13-2014, 03:50 PM   #7
srbarnes4ever
I have not tried that route...will see if there is a difference.
      10-13-2014, 04:33 PM   #8
MRV99
MRV99's Avatar
I have a good friend who is a SA at my dealer and I have spoken at great lengths which him and a few techs about lifetime fills on trans and diffs. They all say that 50-60k is the most the recommend going without a flush and fill. May not be cheap but much cheaper than replacement. I changed the trans fluid on my 540 MSport at 50k and it made the trans much much smoother. The indy shop who swapped it for me said the original fluid was in need of a change
--RIP--
      10-13-2014, 04:51 PM   #9
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
Check the driveshaft recall...cured the clunking for me.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      10-13-2014, 04:55 PM   #10
P1
P1's Avatar
11572
But I just had mine replaced under the recall
      10-13-2014, 04:57 PM   #11
Draper
Draper's Avatar
3461
Could be something else I suppose.
My clunking was only present when slowing down, and the transmission was downshifting at low speeds.
      10-13-2014, 05:00 PM   #12
srbarnes4ever
Drain and fill or flush? I have not quoted the cost at stealer ship, will quote both at Indy shop here. Any comments on Redline sun ATF vs stock ZF lifeguard equivalent?
      10-13-2014, 05:03 PM   #13
srbarnes4ever
Both up and downshifts at low speeds for ours....
      10-13-2014, 05:28 PM   #14
P1
P1's Avatar
11572
Just from 1st to 2nd and 3rd to 4th in mine.
      10-13-2014, 07:10 PM   #15
srbarnes4ever
First to second and second to third in either direction as well as Park or Reverse to Drive has a second or so pause before gear engagement. If under load from decent acceleration, no issues.....
      10-14-2014, 03:28 PM   #16
MRV99
MRV99's Avatar
On my 540 Msport manual I used redline. For my Automatics, I used OEM fluid. I just asked for a transmission service which included new transmission pan and filter (all one piece and made of plastic) and fluid. Not sure if it was completely flushed clean and only new fluid was left. Anyway you cut it, 90% new fluid is better than 100% old
--RIP--
      10-14-2014, 04:21 PM   #17
moeenulhaq
Drives: 2011 X5
Had the same problem on my 2011 X5 with 59K... Got the transfer fluid flushed and reset adaptive drive. Problem Solved!
Always better to flush the transfer fluid first then flushing the transmission fluid.
      10-14-2014, 06:50 PM   #18
godmans
Drives: 135i / 335i / X6M
What fluid did you use bud, for the transfer case?
      10-14-2014, 07:49 PM   #19
srbarnes4ever
Why is this so, if I may ask?
      10-14-2014, 08:42 PM   #20
P1
P1's Avatar
11572
How much does this service goes for?
      10-15-2014, 01:50 PM   #21
moeenulhaq
Drives: 2011 X5
Original BMW transfer fluid.. bought it from the dealership and only took 15 mins to flush and fill.
Ill see if I can find the receipt, cost around $55 for fluid it self.
Update: Found the part# 83220397244
      10-15-2014, 01:53 PM   #22
moeenulhaq
Drives: 2011 X5
I bought the fluid from dealership parts desk for I think around $50ish and flushed it my self, just open the transfer case bolt, fluid will start coming out it self or use a siphon to force flush it and once all out just fill it with new fluid till it starts over flowing. Very easy . will only take you around 15 mins.
