      12-02-2013, 11:05 AM   #1
DustinMN
Drives: 2007 335i 6MT 2011 X5 Msport
E70 X5 35i Intercooler Options
I've searched high and low with scattered info.
Is there a confirmed maker of an upgraded FMIC for this vehicle?
I am planning to run a VRSF on my E92, and would just assume run the same on this car.
What say you?
      12-04-2013, 08:51 PM   #2
DustinMN
Nobody has done this upgrade? Come on, it makes more power on a Cobb 1+ tune than the downpipe does!
      12-05-2013, 11:06 AM   #3
Chio
Chio's Avatar
Drives: G80 M3 Cp, x7 M60
just use a bag of ICE!! LOL sorry but i had to
      12-05-2013, 11:09 AM   #4
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
If you want to make more power, wouldn't it be easier to get a 50i?
      12-05-2013, 06:54 PM   #5
DustinMN
Great logic. I don't want sub 10 mpg for power.
      12-06-2013, 08:10 AM   #6
upstate650
upstate650's Avatar
I get 14-15 mpg in my M.
To each his own. Have fun spending a ton of money to make it marginally less slow. You can buy a lot of gas for what you are going to spend to add intercoolers to a six cylinder.
      12-06-2013, 08:29 AM   #7
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
I Got it on the 50i but 35i? I dont know if they make one
      12-06-2013, 04:43 PM   #8
DustinMN
I'm not asking for power comparisons to the 50, or M, I'm looking for a modest upgrade for the 35. No need to clutter the thread with drivel.
An intercooler will likely fetch $400 for the N55, and be an easy way to modify the tune being run, and get closer to 400whp out of it. That's ideal, since it gets 23+ mpg hwy, rather than 14/15.
I keep the aggressive power to my DD, the N54 335.
      12-06-2013, 05:47 PM   #9
Brian425
Brian425's Avatar
11
Drives: 2012 BMW X5 50i
I would reach out to vendors who make them for the 335. I would guess that with some reasonable modifications you could make them work.
If not, there are few companies that make custom FMICs. It all depends on what you want to spend.
      12-08-2013, 01:16 PM   #10
DustinMN
I've done that as well. I think the only real difference is that the end tanks have symmetrical ports on the E70 intercooler, and the E90/E92 have offset ports, so a simple change of piping/tubing should do the trick. Cobb is confirming what they can do for it.
The VRSF FMIC has been proven to be a great mod for the $ compared to the other makers out there, and the 5" core shouldnt take too much trimming of plastic to fit if the piping can be figured out with relative ease.
      01-03-2014, 10:35 AM   #11
RaceTruk
Drives: F13 M6
i have been looking into this and came across this thread.
http://www.e90post.com/forums/showth...x6+intercooler
the OEM x5/x6 intercooler is already bigger than the OEM e9x/e8x N54/N55 IC.
obviously the size doesnt equal efficiency, but it will def be a less of a difference than on the E9x.
On the E9x/E8x there is a size constriction because of bumper available space.
the E7x dont have that.
OEM on E9x is: Stock
20" W x 5.12" H x 4.5" D
OEM on e70 is
22" W x 6.7" H x 4.3" D
About 1.5" taller, and 2" wider at the core.
Teeny bit not as deep.
if you get any more info let me know.
i am stage 1 Cobb, with a BMS intake (youc an use the F10 535 intake BTW on E70 N55), and have an ER DP sitting in a box which will be installed in about 2 weeks.
Also have a F10 535 CP on order, and would love to finish the bolt ons to make it a nice little racetruk!
      01-03-2014, 06:13 PM   #12
DustinMN
Awesome to see something similar. I did an afe drop in filter. How is the noise from your intake? I'll revisit with josh at Cobb and see if he came up with anything on the fmic. I'd rather do the vrsf personally.
      01-03-2014, 06:41 PM   #13
SteveMD
SteveMD's Avatar
198
Drives: 2016 F10 535i MSport
Do a Google search for 'Big Tom Intercooler'. Legend in N54 land. Prolly work on N55 too.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      01-04-2014, 12:17 AM   #14
RaceTruk
Drives: F13 M6
With the price of vrsf it's not really a good low price option anymore.
I am also not a fan of the tall and skinny FMIC on any bmw.
Most of the FMIC was hidden behind the bumper anyway.
I really didn't see any good proven dyno testing on the big toms.
I had a AMS and switched to vrsf 7"
Saw little improvements switching the the 7" but not much.
AMS is considered pretty good just found a good deal and decided to switch.
      01-04-2014, 12:19 AM   #15
RaceTruk
Drives: F13 M6
The bms makes the car scream,
Me and my friends all thought I was doing a 4 wheel burn out it sounds like a screech and I can hear the BOV on the turbo a lot.
Age is still closed so you most likely hear nothing right?
I highly suggest the BMS, best of all it looks pretty boss.
I just shared all that info with josh today actually he tweaked my stage 1 map a little.
Anyone else running Cobb stage 1 aggressive here?
      01-04-2014, 03:54 PM   #16
DustinMN
So you are running the VRSF 7" core on your E70 then?
      01-04-2014, 05:32 PM   #17
RaceTruk
Drives: F13 M6
No that was on my e93 n54
      07-13-2015, 12:51 PM   #18
r6mikeg
Drives: 2013 x5 msport n55
OEM on e70 is
How will u keep check engine light off with down pipe ?
      07-13-2015, 02:44 PM   #19
omgboost
Drives: 2012 X5 35i
The Cobb tune keeps the light off. If you uninstall the tune, the light will go on.
      07-13-2015, 03:23 PM   #20
socale39
Drives: 04 545i SMG
I thought I saw an intercooler upgrade made by Wagner. Don't have more than that but maybe some google searching might pull something up.
      07-15-2015, 01:04 PM   #21
RaceTruk
Drives: F13 M6
correct
      12-07-2015, 12:16 AM   #22
6lacksheep
6lacksheep's Avatar
Drives: 2016 BMW X6M
any updates on FMIC?
