06-18-2017, 10:45 AM | #1 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Delete.
Delete.
06-18-2017, 12:31 PM | #2 |
Rep 1,044
The X5M only has a different rotor size and caliper bracket and considering the front does most of the stopping it wouldn't be much of an improvement if you just did the rears.
06-18-2017, 04:49 PM | #3 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Delete.
06-18-2017, 08:35 PM | #5 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Delete.
06-18-2017, 09:13 PM | #6 |
Rep 1,044
Ah ok. I was reading it differently. Unfortunately I think your option is to go full Brembo BBK or stick with stock. Going with 4 piston setup in the rear will inevitably change the braking bias therefore requiring a different proporting valve. Of course if the fluid displacement is the same you might be ok but These are things to consider.
06-18-2017, 09:17 PM | #7 | ||
Rep 2,736
But the cars abs system may make it a non issue. |
06-18-2017, 09:37 PM | #8 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Delete.
06-18-2017, 10:54 PM | #10 | |
Rep 2,736
Ok then sounds like it's time to get creative then! you sound like an ass with that comeback, probably not what you intended but posts have a way of not conveying emotion very well. have fun searching. Sorry we could not give you what you want. Spend the 4 to 5k on the brembo kits as they have been tested front and rear and will work well. But the Brembo BBK is actually 5mm smaller than stock in rotor size so just the caliper gets bigger. Lots of money for small return but that's your prerogative. I personally think the rotors are what fills in the wheels nicely not the caliper. If your just looking for looks they sell glue on style covers on eBay ! Lol. Sorry about that I had to... regardless, as small as the carrier is for the stock rear caliper you would have to purchase the rear caliper and make a custom mount. Problem is if the rotor isn't the right width for the aftermarket caliper it could be an issue but it would probably work. Unless you used the rotor that came with the kit but then your rotors would not match. I made custom carriers for my Z4 3.0i to carry 135i 6 piston calipers to mate up to the Z4M rotor so anythings possible. Sky's the limit if you want to throw money at it. Here was my project from years ago when I was relocated to Chicago. Because I did my own engineering and fabrication of the caliper carrier it was a relatively cheap mod, otherwise it can get expensive quickly and possibly dangerous if you don't know what your doing. http://www.z4-forum.com/forum/viewtopic.php?t=36327 |
06-20-2017, 11:43 AM | #12 |
BeastM3r
1286
Rep 1,657
This is what I did
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
06-20-2017, 06:01 PM | #13 |
Rep 994
One does not simply bolt on a "4 piston," caliper without taking into account brake bias.
Brakes work as a system. Smaller piston, more piston force; larger piston, less force. Playing with a MC size can affect pedal effort. More pistons, means smaller pistons, meaning more piston force; not better braking. Just more even application of force to the pads. Most modern cars have a heavy front bias, something 90%+ of braking is up front, and the rears account for around 10% of your braking force. Fiddling with this willy nilly is playing with your life. Think about this as you go down this path... |
06-20-2017, 06:59 PM | #14 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Delete.
06-20-2017, 11:20 PM | #15 |
Rep 1,044
Really don't know what else you are looking for here as it's obvious to me that you already got your answer. I think the difference between this forum and the M3 is that you're likely talking with a different demographic most on this forum likely being older and owning an X5 as a family hauler. I guess my point is most here probably consider function over form and that is why we either see X5M conversions or Brembo BBK as the only options. Let's not forget the M3 market for aftermarket options is also much larger.
06-21-2017, 09:18 AM | #16 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Delete.
06-21-2017, 09:33 AM | #17 | |
Rep 1,695
People don't know your life, they are merely offering opinions regarding safety. But if you're so hurt by the fact that people don't know your credentials, why don't you upload your resume so we know what kind of badass we're dealing with...SMDH... |
06-21-2017, 09:46 AM | #18 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
At this point the thread has been derailed to the point that it's of no further use.
06-21-2017, 09:54 AM | #19 | |
Rep 1,695
Your frustration is understandable, and while you didn't find your answer, the responses you got were with best intentions. Having said that, I would also suggest you keep the thread open and maybe label it "E70/71 X5/6 M Rear Caliper Upgrade" or something to that effect. I'd love to know where this journey takes you...I'm sure a lot of people on here feel the same. Last edited by mirob; 06-21-2017 at 10:16 AM.. |
