      02-26-2014, 08:58 PM   #1
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
Fumoto Valve install
Having the Fumoto valve on my other cars i thought i would install it on the X5. Sure does make changing the oil much easier. Unlock the lever and that's it. Just thought i would share.
      02-26-2014, 09:54 PM   #2
BigBalls
BigBalls's Avatar
Drives: X5
what about if that lever hits some kind stone or gnome and thats it ) unless u riding clean roads but i dont...
      02-26-2014, 10:44 PM   #3
larryv
larryv's Avatar
64
The lever was in the down position as the oil was being drained. When done the spring loaded lever goes up and over a notch. I thought the same thing when installing them on the lowered M3 and Mini, luckily i have never had a problem.
      02-27-2014, 06:59 AM   #4
RllyDrvrIX
Drives: '12 X5
How far does it protrude from the undercarriage panels/structure?
      02-27-2014, 09:28 PM   #5
larryv
larryv's Avatar
64
About 1/2 inch.
      07-22-2014, 03:40 PM   #6
BigBalls
BigBalls's Avatar
Drives: X5
some questions to to the thread owner or others who had installed.
any problems yet, still happy with that fumoto drain valve?
thinking to install it on my car, where did u get it?
whats the right model number for x5 diesel ?
      07-22-2014, 07:46 PM   #7
larryv
larryv's Avatar
64
No problems what so ever. On there website when you enter your vehicle info it will give you the part No. http://www.qwikvalve.com/
      07-22-2014, 09:07 PM   #8
BigBalls
BigBalls's Avatar
Drives: X5
awsome. thank you
      07-22-2014, 09:39 PM   #9
airshaq20
Drives: X5M, E60
I was looking at this a few weeks ago. Quick question, can you still put the plastic cover on? Or do you just leave it off? Thanks.
      07-23-2014, 03:40 PM   #10
larryv
larryv's Avatar
64
Good question. My cpo did not have a plastic cover and did not know there was supposed to be one. I will have to check on that. With this valve the cover cannot be used since it protrudes down about a 1/2 inch.
      07-23-2014, 05:58 PM   #11
mitch808
Drives: 2012 X5 35i
In the industry, they call it "clearancing..." Cut hole, drill hole, use pry bar, or hammer a gap..
Cover or not, I'm sure you can still use the valve and make it all work together...
      07-23-2014, 07:47 PM   #12
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
To me it looks like a perfect way to get hit by debris, lose oil and damage the pan. Nice device, but probably not for this vehicle. Draining the oil on X5 is one of cleanest and easiest I have seen around. Don't fix what's not broken.
