      01-25-2024, 04:23 PM   #1
oil_burner
California Diesel Guy
oil_burner's Avatar
Drives: 13' x5 35d
2nd CEL in 2 weeks
Alright, the x5 has currently been throwing fits of rage at me for no reason. I’ve recently (3 months) replaced the EGR valve and cooler, and just 2 weeks ago I replaced the MAP sensor. Everything was smooth running, but today I’ve got codes p0101, Air Mass Performance, and p0401 EGR flow codes. Any ideas? Bad MAF sensor? Torn vacuum line to the EGR?
Previous Affairs: 2011 335i Msport, 2007 Honda Pilot:, 1991 316i R.I.P
      01-27-2024, 09:29 AM   #2
wcs531
Drives: E90 335xi / E70 X5d
Check out the North American BMW diesel owners group on facebook, there is a lot more technical stuff there to search through and post if you dont find something relevant in your search.
You might get roasted for not having the proper BMW codes, theyll recommend getting Bimmergeeks protools or a handheld scanner that specifically works with BMWs (some kind of foxwell probably). If you're going to be working on the car its almost a must have anyway.
      01-27-2024, 10:42 AM   #3
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Probably a torn vacuum line or a boost leak. I had the same code (not a P code because c'mon, man!) for a MAF issue when I had some small boost leaks. I fixed those and it went away.
