      11-01-2018, 08:50 PM   #1
S65B40YYC
Drives: 08' E93 M3
E70 X5d 12k Mile Road Trip Prep
Hi All,
I just bought an 09' X5d with 97,000 miles I plan on driving from Canada to Mexico this winter putting on 12k miles in 3 months. The car has a mediocre maintenance history. The previous owners were reactive not preventative unfortunately so I am thinking about doing a major service on it including a full EGR, SCR and DPF delete with tune prior to hitting the road. The only thing it really needs immediately is the glow plug controller as it has a check engine light for this and the lower control arms. The items I plan on doing for reliability and preventative maintenance are listed below and I am wondering if I am missing anything or if I could defer some of these items, thoughts? :
- Oil, air, cabin and fuel filters
- Brake, coolant, front/rear diff, transfer case and transmission fluid flush
- Transmission mechatronic sleeves
- Water pump, thermostat, tensioner pulley, idler pulley and harmonic balancer
- Serpentine belt and ac belt
- Glow plugs and glow plug controller
- Intercooler and intake charge pipe O-rings
- All vacuum lines
- Intake manifold gaskets
- Swirl flap delete and EGR delete
- DPF delete exhaust system consisting of a cat less down pipe 3” and a mid section
- Lower control/thrust arms
      11-01-2018, 10:44 PM   #2
RichardR0404
Drives: 2013 BMW X5 35D
New tire, brakes. A tune. Shocks and control arms, coffee
      11-01-2018, 11:25 PM   #3
S65B40YYC
Drives: 08' E93 M3
It has new tires and brakes front and rear. Tune is a required for sure...
Shocks would be nice but even at this rate I will be spending thousands reconditioning to get this thing reliable. I definitely do not want a breakdown in middle Mexico with this vehicle.
      11-02-2018, 12:28 AM   #4
X5 MAN
Drives: 2011X5 50iM-Sport;2016X3 35i M
Just rent an SUV similar in size to X5.
Why spend so much cash on your own X5 and put 12 k miles on it ?
      11-02-2018, 11:03 AM   #5
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
Where you headed? Cabo?
Should be awesome, i would preventative replace many cooling components, hoses, clamps, expansion tank, etc. Take a look at your fuel pumps/sensors as well
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      11-02-2018, 12:05 PM   #6
omgboost
Drives: 2012 X5 35i
Why buy a car and not drive it? Most of the items on the list look like maintenance items that need to be addressed at that mileage regardless of the 12k mile road trip.
      11-03-2018, 02:18 PM   #7
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
Originally Posted by S65B40YYC View Post
Hi All,
- All vacuum lines
hopefully it's not a BPC tune
why are you replacing the glow plugs and glow plug controller if there's no codes?
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
      02-05-2024, 12:22 PM   #8
dilbob81
Drives: 2012 bmw E70
https://www.bimmerpost.com/forums/sh...php?p=23940667
Sunny_j
Is that a common problem with BPC tunes? I have a BPC tune and it doesn’t like starting in cold weather. Are they known for messing up the glow plug cycle?
      02-06-2024, 06:16 PM   #9
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Check your rain trays and fuel pressure sensor (they go bad and leak fuel into the DME). Bring an extra ground strap with you as well.
      02-06-2024, 06:52 PM   #10
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
So what did you end up doing to the X5, and how was the trip S65B40YYC
