      04-15-2018, 07:32 AM   #1
MCB_X5M
MCB_X5M's Avatar
Drives: 2011 X5M
Faults on Carly
Hope you all have some insights as to the significance or lack of significance for the fault codes displayed from Carly... I just picked the Carly unit up last night so still figuring things out.
Appreciate any thoughts about the codes displayed! FYI, I'm in a 2011 X5M.
      04-15-2018, 07:41 AM   #2
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
Clear faults.
Go for drive.
Check again.
m5james431.00
      04-15-2018, 10:14 AM   #3
RichardR0404
Drives: 2013 BMW X5 35D
Clear everything, go through couple power cycle. Then see what's remaining code.
m5james431.00
      04-15-2018, 10:18 AM   #4
MCB_X5M
MCB_X5M's Avatar
Drives: 2011 X5M
Thanks, will post back after I reset
      04-15-2018, 01:23 PM   #5
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Turbo pump failed on mine as well, it's about an $80 part. I could hear it running/grinding itself to death after I shut the engine off. Kind of a tight area on the front passenger side of the engine but comes off easily with two bolts and one harness.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
