      08-02-2018, 08:19 PM   #1
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
how do you take off start engine button?
im looking to swap to the red button but i cant seem to take off the stock button after taking off the trim. any help?
      08-03-2018, 11:00 AM   #2
bandwagn
bandwagn's Avatar
232
Drives: 2006 325xi
2010 X6M  [0.00]
2006 330Cic  [0.00]
It should just pop off - there are a couple of plastic clips (you should be able to get reference points from the new button face)
      08-03-2018, 01:22 PM   #3
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
remove the front cover (using plastic tool) u'll see 3 screws holding unit in place, remove it, remove the unit, disconnect it, carefully remove the button and put new one in place, put back the same way!
I wouldn't suggest popping the button as is as you most likely will brake the tabs, the full procedure shouldn't take more than 10 min!
do_0b54.50
