      01-23-2011, 08:11 PM   #1
spdfrk
spdfrk's Avatar
Drives: 2011 X6M/2011 X5.35d
X6M brakes squeek when cold!
Does anyone else have this problem? When the temperature gets below -5 cel the breaks make an awful squeaking!
      01-23-2011, 08:50 PM   #2
bmr760
bmr760's Avatar
Drives: G80 M3C, F90 M5C, G05 X5 40i
not an X6 M but my X5 M does the same and its only 40+ out.
      01-24-2011, 11:32 AM   #3
BabyBlack
BabyBlack's Avatar
27
Drives: E46 M3 & E90 335i & E71 X6M
Common problem for the X_M. Loud as an air horn when applying brake on reverse
      01-24-2011, 12:19 PM   #4
zaha
zaha's Avatar
Drives: Bmw X6M
A bunch of posts on here about that problem. I have the same BS and have been told by the kind people @ Bmw that it's just the compound of the brakes. It goes away if you speed up to around 80km/hr and slam the brakes VERY hard.
I plan on solving this issue in the future by buying a car from a manufacturer that winter tests their vehicles
      01-24-2011, 08:02 PM   #5
DARE U
Common problems for all the performance brake system. Once heated up everything will go back to normal again (this is what few BMW workshop had told me). So far, when mine is heated up, the sound is gone.
      01-25-2011, 07:59 PM   #6
ARam
ARam's Avatar
61
Drives: 2016 BMW X5M
Jezzz!!!!! Finally a post or this issue
I'm having the same issue with my X6 3.5 (only 4000miles) and I have taken the vehicle to TWO different service center to be told the same thing "This is normal due to the weather/temp/salt/brake dust
      02-05-2011, 05:23 PM   #7
BimmerGeorge
Drives: 2011 X5M
Had the same problem; brakes squealed like a banchie when I backed out of the garage in the early am. Wife loved it as it woke her up everyday at 6. Dealer said common problem on x5 and x6 M models. They replaced pads and rotors and so far so good since.....
      02-06-2011, 12:16 AM   #8
bleudyno
bleudyno's Avatar
75
Drives: 2010 Melbourne Red X6///M
2010 X6M  [9.50]
2010 X6M  [0.00]
I took my car in for this problem twice! My car had really loud squeeking only when backing up no matter what the temperature. First time the dealer replaced the rear brake pads. Second time they replaced the whole rear brake system (rotors, calipers, and fixed. BMW said they would do this as a one time courtesy. WTF? How is it a courtesy when they are SUPPOSED fix the problem??
Brakes still squeek!!!! I asked my service advisor what they would do next and he said that they will probably have to have BMW send a technician to take a look at it to see what the problem is. I really don't understand what is wrong. Has anyone taken their car in for this problem and actually had the problem fixed?
X6///M Melbourne Red/Merino Black leather MODS: Matte black grill, Tinted head lights, Euro clear side reflectors w/ tint, Tinted white stip on tail lights, 22" Iforged Legacy Convave (Matte black center with Gloss black lip) RPI Race exhaust, Vorsteiner CF front lip, CF rear deck lid spoiler, CF rear diffuser, vented CF race hood, RPI intake scoops UPCOMING MODS: RPI software tune
      02-06-2011, 10:15 AM   #9
Bob MG
Moderating
Bob MG's Avatar
United Arab Emirates
418
Drives: like a muppet
Exactly the same
Problem when reversing out of driveway
Stops after you drive off
      02-06-2011, 02:21 PM   #10
Cdnrockies
Drives: BMW's
This isn't exclusive to the X6M. Happens in Dad's X6 , my X5 35d and for that matter in my IS F as well...less so in the ML.
Low temps and performance pads don't mix apparently.
      02-06-2011, 07:23 PM   #11
BimmerGeorge
Drives: 2011 X5M
As I said I had the same problem on my X5M. It was really loud. The service manager at McKenna in Downey said this is a common problem. For whatever reason it only happens in reverse. I was told it was only occurring on the X5 and X6 M models. They did brakes and rotors two weeks ago and I haven't heard it since. If it happens again u can bet I'll b paying them another visit....I think with problems of this nature it all comes down to the dealer's willingness to make the effort to solve the problem. In my case I purchased the vehicle as a demo from McKenna so they may have been more accommodating because of that. Good luck!
      02-06-2011, 08:02 PM   #12
LANDLORD
Turbo Engines are Fun
LANDLORD's Avatar
Drives: 2010 X6M Monte Carlo Blue
I am going to try the Brembo brake bedding procedure below, and see if this helps the situation:
•While the vehicle is stationary, pump brakes to ensure a firm pedal.
•Drive the vehicle cautiously to test fit and function.
•The brakes should be smooth, with no vibrations, judder, etc.
•Drive the vehicle to a remote area and perform at least 30 brake applications of 3-second duration. Use light/medium deceleration with varying starting speeds. Leave at least ˝ mile between each brake application.
•The purpose of this procedure is to gradually increase the temperature in the components without inducing thermal shock, and to mate the brake pad and disc friction surfaces.
•After the repeated stops, drive the vehicle for several miles with little or no braking in order to adequately cool the components.
•After the above process is completed, the system is ready for normal use.
•When the system achieves elevated brake temperatures for the first time, a slight increase in pedal travel and pedal effort may occur. After this first "fade" and proper cooling, the system will maintain its optimum performance at all temperatures.
      02-14-2011, 01:06 PM   #13
donidion
Drives: bmw x5
i have not that problem because temperature never -5c
      02-14-2011, 01:07 PM   #14
donidion
Drives: bmw x5
actually i dont have bmw car....it is still my dream car
      02-14-2011, 01:09 PM   #15
donidion
Drives: bmw x5
i am interst in mercy than bmw....i love mercy model more trendy now
      02-15-2011, 08:59 PM   #16
quitethesnapper
bimmerlover
quitethesnapper's Avatar
Drives: the panzer
Brought my dad's in today for the brakes, same loud squealing. SA says there is a recall for just the pads. I will keep you guys posted when I get the truck back on Tuesday.
      02-20-2011, 01:25 AM   #17
WheelsCollection_Billy
Drives: 2015 F80 M3
All the X6M has that problem. Is the brake pads design's problem.
It is a recall. Go back to your dealer and change the new pads will fix that problem.
      02-25-2011, 04:42 AM   #18
meinauto
Drives: E92 335
Recall
does anyone have the SIB on the brake pad recall? tks!
      02-26-2011, 10:03 AM   #19
quitethesnapper
bimmerlover
Drives: the panzer
Got the X5M back and they replaced the pads, not one sound. I will get the info on the recall and post shortly.
      02-26-2011, 10:29 AM   #20
NYCGP
WTF are you looking at?
NYCGP's Avatar
232
Drives: Bandwagon
Sound will come back... They are performance brakes made to stop a 2 and a half ton vehicle. Name another vehicle on the road that weighs as much as your X6/5 M and can stop in such a short distance. Not to mention last during long periods of abuse.
To keep the sound away you will need to replace pads often. Well before they are worn.
"It is better to be hated for what you are than loved for what you are not."
-André Gide
      02-26-2011, 11:47 AM   #21
1230vani
1230vani's Avatar
Drives: G05 40i LCI
It could be it is a BMW performance material issue, BMW changed TWICW under warranty performance brakes (second time incl.discs) on my E92, as they were making noise. Just in case, one thing to watch out for is the spray used to clean the wheels, make sure you either wash it off properly or not use it as it could lead to the brakes squeeking as well.
      02-26-2011, 12:01 PM   #22
skim175
Drives: X-drive
My 135 is squeaky and it is quite embarrassing. But X5 does not make any noise.
