Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Pressure washer/air compressor combo
      10-03-2021, 06:17 PM   #1
E92inNC
E92inNC's Avatar
1710
Drives: E92 335i
Looking for some suggestions to buy around Black Friday or Xmas time. For use only on my car and I wash every 2-4 weeks and detail twice a year so don’t need anything high end, just has to do the job and ideally last 5+ years.
      10-03-2021, 10:56 PM   #2
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
You plan on using a pressure washer on the paint? Foam cannon yes, pressure washer no.
      10-04-2021, 09:35 AM   #3
E92inNC
E92inNC's Avatar
1710
Drives: E92 335i
Why not? I’ve worked at several dealerships in years past and have used them on several of my cars including my E92.
      10-07-2021, 06:16 PM   #4
dmatre
Drives: 2011 328i Sedan
We've got the Ryobi 2300psi unit from Home Depot. Works great for foam gun and rinsing wheels/wheel Wells/paintwork. Makes bug & tar removal much easier.
If you've got a crappy repaint, maybe you can damage the paint with a pressure washer, but BMW factory paint - no way.
Just keep the nozzle about a foot or more away and you'll be fine.
E92inNC1709.50
      10-07-2021, 09:42 PM   #5
E92inNC
E92inNC's Avatar
1710
Drives: E92 335i
Thanks, I’ll put Ryobi on my list come the buying season. I’ve looked and it seems there aren’t any 2 in 1 air compressor/pressure washer combo.
      11-12-2021, 09:03 AM   #6
JoeVan303
Drives: BMW 335IS
I picked up a Simpson 2800psi a few black fridays ago and it works great, you can use the different nozzles to adjust the pressure, I usually use the white one which is like 40*, very gentle, I wouldn't worry about chipping the paint.
Foam gun a must as well, it attaches right to the pressure washer, worth the purchase. I got this one:
E92inNC1709.50
      11-14-2021, 10:39 PM   #7
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
These 2 are on my list now after some research, seems to be the best quality/value and maybe some extra fittings and longer hose you should be set
https://www.amazon.com/gp/product/B0...TXKQ1A1S&psc=1
https://www.amazon.com/gp/product/B0...WIBJGZ9N&psc=1
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
E92inNC1709.50
      03-30-2022, 11:54 AM   #8
ryan stewart
Drives: 2008 328it
to add to this I have fallen in love with using this thing:
https://www.ryobitools.com/products/details/46396036766
Specifically you will want the HP one, its 600psi instead of 300psi and better made. But man it works for washing the car. Its half has powerful as a real pressure washer which, for me, is perfectly fine. If you need to scrub concrete you just have to get closer, so the job takes longer, but for washing the car its a HUGE help. There is a foam cannon you can attach to it as well which works well.
Im reminded because I just, over lunch, prepped the car for a real bath after work. Sprayed the brake dust off the wheels and got the bugs off the front. So that way this afternoon its just spray, foam, wipe (with a mitt to just get good soapy coverage), rinse, then hit it with leaf blower and then microfiber.
So much easier than messing with a full pressure washer rig.
