      07-31-2019, 07:25 AM   #1
MLB607
MLB607's Avatar
Drives: 2012 750li M-Sport
Can the Soft Close feature be disabled?
So my driver side front soft close has stopped working and is now making a horrible noise every time I close the door. Im sure its the motor but I was hoping that maybe someone has done or knows how to shut the feature off completely. Anyone?
2014 Alpine White 535i M-Sport
2012 Black Sapphire 750li M-Sport (sold)
2011 Carbon Black 50i X5 M-Sport (RIP)
2013 Black Sapphire 50i X5 M-Sport (sold)
      07-31-2019, 09:15 AM   #2
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
possibly you can take out the actuator or unplug it?
      07-31-2019, 10:03 AM   #3
MLB607
MLB607's Avatar
I would think that would work although I'm not sure if that would render the locking mechanism inoperable. I guess I could take the cover off and give it a shot. The new motors are like $200 on eBay and quite frankly, I'm not really concerned with the soft close working so I just figure not even fix it if I can just make it close regularly without this horrendous noise after closing.
      07-31-2019, 11:35 AM   #4
ryansbmw
Drives: 2013 X5 35i M-Sport, 2010 535x
Ill try to remember and look at my Protool tonight and see if the coding options are there. I want to say 'yes', but not 100% sure.
VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
Need coding or modules reset? PM me
      08-01-2019, 06:14 AM   #5
MLB607
MLB607's Avatar
Oh that would be great, I really appreciate it.
      08-01-2019, 01:34 PM   #6
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
too bad its not the driver side rear door, i have a brand new motor that i would let go for cheap. Was going to replace my motor but i got rid of the car so its just sitting here now.
      08-02-2019, 08:23 AM   #7
MLB607
MLB607's Avatar
Ya that would have been nice considering I just don't wanna spend so much for one right now
      08-04-2019, 05:59 PM   #8
MLB607
MLB607's Avatar
Anyone?
      08-05-2019, 06:30 AM   #9
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
I have the same issue with my driver side front door but without the noise. Found a mint motor on ebay and got it. Look for a good used one on ebay...
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
      08-05-2019, 08:12 AM   #10
Sophisticated Redneck
Drives: 2012 BMW X5 50i
It should be called the "automated mistress door close function" I swear some BMW engineer came up with this idea so he could come home late at night and not wake up the wife with a door slam)
Mine did the same thing, you can take off your door panel (videos on youtube how to do this)and pull the wiring harness from the motor. It's a bit tricky to do though as you have to do it all by feel unless you pull the entire motor and latch assembly. I am sure there is a fuse that controls the entire system but not sure what it is.
I replaced mine which wasn't a bad job, BMW left just enough room to do it without having to take out the window regulator, just loosen it a bit on the bottom.
If your decide to replace it, I would stay away from the cheap units, they are knock-offs and don't last long according to reviews. Get a lightly used one off eBay like mentioned above...or open up your wallet...I think I paid close to 400 for mine new....
      08-05-2019, 10:34 AM   #11
heatmizr
Drives: E70 X5 50i M-Sport
Do the motors from the other doors interchange with this door? At least check, and then if yes can move the motor from a door that you rarely use to the driver door.
      08-06-2019, 09:12 AM   #12
MLB607
MLB607's Avatar
All good advice. Thanks guys. Moving one of the motors would be a great fix since let's be honest, the only two doors that get used most of the time are the fronts. I'll have to get in there and see if I can screw with it. I'm mayen I'll take it to my mechanic and see if he can't disable it with his computer.
      08-07-2019, 08:26 AM   #13
heatmizr
and it would be free if you can DIY!
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
MLB60721.50
      08-13-2019, 01:33 PM   #14
BMW-SRT
Drives: C63sAMG, GLC63sAMG, x5m, 335i
whats the part number on the motor (or link)? mine just started acting up and makes a weird noise once in a while
      08-30-2023, 11:04 PM   #15
afy511
Drives: x5 n55 35i 2011
You can remove the fuse if it annoys. I had fixed mine
