Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Anyone had paint defects, specifically clear coat failure?
      06-22-2019, 02:38 PM   #1
drunkentrader
Drives: 2009 335i coupe.
Super bummed that my 2009, 70k mile Le Mans blue 335 started developing bubbles on the roof a year ago, which obviously led to the clearcoat peeling off in small sections, all the while spreading.
No big deal, right? It’s just the roof - I could always strip the clear and have it wrapped in jet black or Shadowline black to match my trim!
...but then the ultimate insult happened - my freakin hood just developed the same quarter sized delamination/bubble in the clear. Now I’m pissed.. this is the “newest/low mile” car I I’ve owned(out of 30+, most of which were bmws) and never once have I had to paint a panel.
Clearly beyond the factory 3 year warranty on paint. But.. curious to hear if anyone else has found their factory paint to become defective prematurely. My mechanic said it’s common on Le Mans blue bmws, but I can’t really find any evidence to prove it being beyond anecdotal.
Anyone ever try to file complaints with BMW NA? It’s seems futile to try on a 10 year old car, but maybe there is a minute chance if it has been documented that certain colors were doomed from the start due to a paint supplier fault, or some other equivalent.
Note: my car has had paintwork performed by the previous owner(rear quarter), but the hood and roof are definitely factory virgin panels. Car is not garaged, but is washed and spray waxed every two weeks.
      06-26-2019, 10:04 AM   #2
BluAnimal
BluAnimal's Avatar
Drives: F30 BMW 330i Manual
My E92 has clear coat failure on the hood and roof. Granted, car sat outside for most its life before I purchased it. Florida sun is dangerous. Planning to get it repainted in the coming months, gotta quote for $800 to repair it.
2007 328i Coupe Montego Blue
      06-27-2019, 01:01 PM   #3
bbnks2
Drives: 135i N55
neglected paint. Gotta keep your car waxed...
      06-27-2019, 07:18 PM   #4
MEN54
MEN54's Avatar
237
Drives: 2017 BMW 330 xi
Ceramic coating
      06-27-2019, 07:48 PM   #5
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
My ceramic coated E90 is mostly garaged. It sat outside for two weeks when I went to Qatar. I came back and the clear on the roof failed. I covered it with paint match vinyl wrap.
      07-02-2019, 04:36 PM   #6
Korz55
Drives: 2009 328xi MT Coupe
My clear coat started flaking on the hood. My car is a 2009 coupe also - must have been something wrong with the paint in Germany
      07-02-2019, 06:46 PM   #7
Cogitoergosum
Drives: 1M
Mine too. 2011 California car with 70k. The roof is starting to fade. It just leave the roof rack on it to cover it up!!
      04-03-2020, 04:14 AM   #8
Snoball M3
Snoball M3's Avatar
Drives: 2008 328i MB Sedan/11.5 ZCP M3
BM  [0.00]
My E90 Monaco Blue roof is all gone, trunk is half way peeled and now the doors are starting to peel a little but getting worst... I'm going to have it repainted later on.
2008 328I MB M-Sport E90
2011.5 E90 AW ZCP M3
1965 C-10 SWB (bagged)
      04-15-2021, 10:21 PM   #9
Benniese90
Drives: 2006 BMW 325i e90
my e90 monaco blue clearcoat was bubbling, cracking, and peeling on the trunk. I went to wal mart and bought a couple cans of clear gloss top coat in the automotive section and layered in on with about 13 coats drying about 15-30 minutes between coats and it looked awesome for months. I had to delicately sand down the failing cracking parts first and wrap the car in plastic to keep it off of the rest of the car. but i did it in the sun and mild wind. However, last month i was installing a new pressure regulator in the gas tank as my brother was watching/helping and he put a gasoline soaked towel on my trunk and it screwed it up so now i gotta sand it back down and redo it.
my point is its a cheap and easy fix that actually looks really good, restores that factory shine, doesnt look ghetto, and holds up to the sun, rain, and machine and hand washes just like the factory stuff does.
      04-15-2021, 10:26 PM   #10
IllSic_Design
IllSic_Design's Avatar
Drives: 09 E92 335i
If you are going to clear the car yourself using a rattle can, use a GOOD 2k clear coat like this; https://www.amazon.com/U-S-Chemical-...pcontext&psc=1 . 2k clear will be way more durable and look better.
      04-16-2021, 01:43 PM   #11
Benniese90
thanks for the tip.
      04-16-2021, 01:57 PM   #12
ky0u
ky0u's Avatar
Drives: e92 335i, f22 m235i, e30 325is
2015 BMW M235i  [0.00]
1988 BMW 325IS  [0.00]
2007 BMW 335i  [0.00]
My roof, hood, and trunk had clearcoat damage when I bought my car. On the hood and roof, the damage actually went through to the paint underneath. I ended up wrapping my whole car a different color
IG: @lolhpfp
Build Thread
      07-21-2021, 11:04 PM   #13
e90burgundy
Drives: E90
I had clearcoat failure - e90, Burgundy red. Here in Bay Area, I am told that I need to repaint the car and the lowest quote is $2500. Maaco says they might be able to do it for 2K. Sounds painful, but is that the best option? I am not super handy
      09-18-2023, 02:04 PM   #14
Thorin
Drives: e91 6MT ZSP
Skip Maaco.
I'm going to go to RJs in Pleasanton to get a quote on paint work (mostly clearcoat failure)
